PR #2920 [Stylesheets] Missing SVG for vertical toolbars added
pablogil
Post by pablogil » Mon Jan 20, 2020 9:45 pm
I have just added a missing SVG for vertical toolbars.
GitHub: https://github.com/FreeCAD/FreeCAD/pull/2920
Cheers
JoshuaCall
Re: PR #2920 [Stylesheets] Missing SVG for vertical toolbars added
Post by JoshuaCall » Mon Jan 20, 2020 10:30 pm
Pablo,
I have a somewhat related question for you. When looking at your commit, I noticed that you have material in the FreeCAD codebase that is licensed under Creative Commons Attribution-ShareAlike 4.0 International License. It is easy to find online documentation that says that the CC BY-SA 4.0 is compatible with the GPLv3. However, the FreeCAD source code is supposed to be licensed under LGPL version 2 or superior. It's possible that these licenses (CC BY-SA 4.0 and LGPLv2+) are not compatible. I'm wondering if you have any thoughts on these license issues, if you are willing to relicense your code under the CC0 license, or if anyone has a document that explains that these licenses are compatible.
Thank you,
Joshua
