Compile error for Qt Designer Plugin
usbhub
Post by usbhub »
I'm trying to build the QtDesigner plugin to create a settings page. I downloaded the FreeCAD source repo and ran qmake plugin.pro, but if I try to run make, it fails:
otto@CELSIUS-M470-2:~/Dokumente/FreeCAD/src/Tools/plugins/widget$ qmake plugin.pro
otto@CELSIUS-M470-2:~/Dokumente/FreeCAD/src/Tools/plugins/widget$ make
g++ -c -m64 -pipe -O2 -D_REENTRANT -Wall -W -fPIC -DQT_NO_DEBUG -DQT_PLUGIN -DQT_SCRIPT_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQDESIGNER_EXPORT_WIDGETS -I/usr/share/qt4/mkspecs/linux-g++-64 -I. -I/usr/include/qt4/QtDesigner -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtScript -I/usr/include/qt4 -I. -I. -o customwidgets.o customwidgets.cpp
customwidgets.cpp:24:10: fatal error: QtGui: Datei oder Verzeichnis nicht gefunden
 #include <QtGui>
compilation terminated.
Makefile:223: recipe for target 'customwidgets.o' failed
make: *** [customwidgets.o] Error 1
How can I say make, where QtGui is?
Founder
Re: Compile error for Qt Designer Plugin
Post by wmayer »
QtGui is a file inside the QtGui directory of the Qt headers. Have a look at the generated Makefile and the list of include paths.
vocx
Post by vocx »
usbhub wrote: Wed Mar 25, 2020 8:04 pm
Running just qmake may run the Qt4 version.
If you are compiling for Qt5, as the majority would do, you need to make sure you are using the Qt5 version.
cd freecad-source/src/Tools/plugins/widget
/usr/lib/x86_64-linux-gnu/qt5/bin/qmake plugin.pro
make
Compile_on_Linux
usbhub
Post by usbhub »
wmayer wrote: Wed Mar 25, 2020 9:07 pm QtGui is a file inside the QtGui directory of the Qt headers. Have a look at the generated Makefile and the list of include paths.
You mean this, right?
INCPATH       = -I/usr/share/qt4/mkspecs/linux-g++-64 -I. -I/usr/include/qt4/QtDesigner -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtScript -I/usr/include/qt4 -I. -I.
Honestly, I don't really understand the Makefile, but for me "-I/usr/include/qt4/QtGui" looks like QtGui is included.
@vocx
Oh, right, I forgot. But the error is still there wit Qt5.
usbhub
Post by usbhub »
Bump :)
Any information missing?
Founder
Post by wmayer »
Independent of whether Qt4 or Qt5 is used you have the following include paths:
Now the compiler tells you that QtGui cannot be found. Does the directory /usr/include/qt4/QtGui actually exist and if yes does it include the file QtGui?
Btw, it would be helpful to tell us which OS exactly you are using.
usbhub
Post by usbhub »
wmayer wrote: Thu Apr 09, 2020 8:24 am Independent of whether Qt4 or Qt5 is used you have the following include paths:
The folder /usr/include/qtXX didn't existed, so I installed all packages beginning with qt4, now it works :)
Now I will try to do it for qt5.
Thanks for your help!
PS: Just for completeness:
OS: Linux Mint 19 Cinnamon
vocx
Post by vocx »
usbhub wrote: Fri Apr 10, 2020 11:04 pm ...
Are you even following the compiling information? Compile on Linux tells you which dependencies you need to install for Debian/Ubuntu based distributions.
usbhub
Post by usbhub »
vocx wrote: Sat Apr 11, 2020 3:18 pm
Yes, that would be a very good idea…
For QT5 it worked "out of the box" after installing the dependencies :)
Thank you very much!
