Gui::QuantitySpinBox miss QAbstractSpinBox inheritance
uwestoehr
Post by uwestoehr » Thu Mar 26, 2020 11:13 pm
I noticed an issue in FC's definition of Gui::PrefUnitSpinBox and Gui::QuantitySpinBox.
They don't inherit e.g. the alignment property from QAbstractSpinBox. Other spin boxes have this and therefore support these useful settings:
QAbstractSpinBox properties
Is it OK to add this inheritance? I would e.g. like to set the alignment for all spin boxes in a dialog, not only for the Q spin boxes.
uwestoehr
Re: Gui::QuantitySpinBox miss QAbstractSpinBox inheritance
Post by uwestoehr » Thu Mar 26, 2020 11:28 pm
Hmm, looking in the code, they seem to do but Qt designer doesn't not recognize them. I can also not find anything about this in
https://wiki.freecadweb.org/Developer_hub
I also searched the Wiki.
So how can I tell Qt designer how to handle the GUI:: widgets?
wandererfan
Post by wandererfan » Thu Mar 26, 2020 11:39 pm
They already inherit QAbstractSpinBox. Maybe your plugin (libFreeCAD_widgers.so on linux. don't know about Win) is not up to date?
see QuantitySpinBox.h
class GuiExport QuantitySpinBox : public QAbstractSpinBox, public ExpressionBinding
and in Qt5 Designer:
Site Admin
Post by wmayer » Fri Mar 27, 2020 7:33 am
It's not a matter of inheritance but a matter of the lack of the Qt plugin. It's possible to use custom FreeCAD widgets in the designer without the FreeCAD plugin but its usage is limited. If you look at the XML code inside a .ui file and search for QuantitySpinBox you can see that adding custom properties is possible and at the end you will see there is a block:
  <customwidget>
   <class>Gui::QuantitySpinBox</class>
   <extends>QWidget</extends>
   <header>Gui/QuantitySpinBox.h</header>
  </customwidget>
The problem here is that in real C++ QuantitySpinBox inherits from QAbstractSpinBox but it's not possible to say so in the .ui file because QAbstractSpinBox is an abstract class and cannot be instantiated. If you try it anyway the designer raises an error when loading the modified .ui file.
To have full access over QuantitySpinBox in Qt designer then the only option is to build the FreeCAD plugin and put it into the plugins directory of your Qt installation.
uwestoehr
Post by uwestoehr » Fri Mar 27, 2020 12:14 pm
I want to do so and document this in my build on Windows instructions in the Wiki. However, it is not yet clear to me how this is done.
In my build folder I find the folder "QtUiPlugin" that contains custom Qt designer widgets. But how do I say Qt designer to use them?
Site Admin
Post by wmayer » Fri Mar 27, 2020 1:44 pm
You must build this plugin: https://github.com/FreeCAD/FreeCAD/tree ... ins/widget
On Windows open command line shell from within VS or of the VS installation in the start menu. Then cd to the directory and enter
qmake plugin.pro
nmake -f Makefile.Release
Copy the dll to the designer sub-directory of the plugins folder of Qt.
uwestoehr
Post by uwestoehr » Fri Mar 27, 2020 3:21 pm
qmake plugin.pro
Thanks. However, I am not able to build this, because despite I am in the VS shell for x64, it tells me that the target destination is x86:
I cannot find a way to tell qmake and nmake to use the x64 version.
wandererfan
Post by wandererfan » Fri Mar 27, 2020 4:21 pm
do you have both Qt4 and Qt5 installed? If so, you may need to point at the Qt5 version of qmake.
I've run into this on Linux, don't know if it applies to Win.
uwestoehr
Post by uwestoehr » Fri Mar 27, 2020 5:09 pm
I only have Qt 5.12.1 installed here.
Site Admin
Post by wmayer » Fri Mar 27, 2020 5:23 pm
You can also try: qmake -t vclib plugin.pro to create a VS project.
Who is online
Users browsing this forum: No registered users and 2 guests
