new compilation warnings in NaviCube.cpp
uwestoehr
Post by uwestoehr » Tue Apr 07, 2020 10:27 pm
Compiling master I get now these new warnings:
D:\FreeCADGit\src\Gui\NaviCube.cpp(977): warning C4305: 'argument': truncation from 'double' to 'GLfloat'
9>D:\FreeCADGit\src\Gui\NaviCube.cpp(978): warning C4305: 'argument': truncation from 'double' to 'GLfloat'
9>D:\FreeCADGit\src\Gui\NaviCube.cpp(986): warning C4305: 'argument': truncation from 'double' to 'GLfloat'
9>D:\FreeCADGit\src\Gui\NaviCube.cpp(987): warning C4305: 'argument': truncation from 'double' to 'GLfloat'
9>D:\FreeCADGit\src\Gui\NaviCube.cpp(995): warning C4305: 'argument': truncation from 'double' to 'GLfloat'
9>D:\FreeCADGit\src\Gui\NaviCube.cpp(996): warning C4305: 'argument': truncation from 'double' to 'GLfloat'
triplus, since you added the code, can you please have a look?
triplus wrote: .
adrianinsaval
Re: new compilation warnings in NaviCube.cpp
Post by adrianinsaval » Tue Apr 07, 2020 11:35 pm
https://www.daniweb.com/programming/sof ... e-to-float
According to this adding an f at the end of the numbers should remove the warnings by telling the compiler you just want a float not a double. I don't know much C++ and just wanted to satisfy my curiosity so take it with a grain of salt
vocx
Post by vocx » Wed Apr 08, 2020 3:31 am
Lines 977-978
glVertex3f(-1.1 , -1.1, -1.1);
glVertex3f(+0.5 , -1.1, -1.1);
Lines 986-987
glVertex3f(-1.1 , +0.5, -1.1);
Lines 995-996
glVertex3f(-1.1 , -1.1, +0.5);
I think every 1.1 can be substituted by a, as we have this definition.
float a=1.1f;
And then a new definition could be made for 0.5 as well.
float b=0.5f;
triplus
Post by triplus » Sun Apr 19, 2020 3:59 pm
Will take a look in the following days.
triplus
Post by triplus » Mon Apr 20, 2020 7:03 pm
Thanks for reporting. I took a look on Travis and indeed on Windows builds such compiler warnings are detected. Hopefully the following PR will resolve the issue.
https://github.com/FreeCAD/FreeCAD/pull/3372
uwestoehr
Post by uwestoehr » Mon Apr 20, 2020 10:45 pm
Hopefully the following PR will resolve the issue: https://github.com/FreeCAD/FreeCAD/pull/3372
Yes, this fixes it. Thank you.
Who is online
Users browsing this forum: No registered users and 1 guest
