Lazy loading of python modules
Re: Lazy loading of python modules
Copying to Ext works for the build, need to check the right path for install. Modified most of the external imports to use lazyloader in path. It cuts the workbench load time from about 15 seconds to around 3, everything still appears to be functioning correctly. It's committed to the branch I posted earlier.
Thanks.etrombly wrote: ↑Fri Apr 10, 2020 12:57 am Copying to Ext works for the build, need to check the right path for install. Modified most of the external imports to use lazyloader in path. It cuts the workbench load time from about 15 seconds to around 3, everything still appears to be functioning correctly. It's committed to the branch I posted earlier.
I will try to build and test your branch on Win in the next days.
"fight the good fight"
Everything installs OK. I think Ext is the proper place. Activation of Path is significantly improved. Nice work!
OS: Windows 10 (10.0)
Version: 0.19.20513 +4 (Git)
Branch: lazyloader
Hash: a42219163aec573870a5f1f5f034a7396b6cb3f8
Python version: 3.6.8
Qt version: 5.12.1
Nice!
@sgrogan why not add it to src/3rdParty per the suggestion of @vocx ?
3rdParty isn't on the python path. That's where I put it in the source, but install it to Ext.
Thanks for testing @sgrogan. Need to figure out why the tests are failing with python 2 now, don't have a dev environment setup for it though. May take me a while.
I think this is the correct solution. Thanks @vocx as well. 3rdPary is the correct place in the src. We are trying not to have 3rd party source if there is a maintained package that can be a dependency. In this case we are using a small subset of the existing package so I think it makes sense to include in the src so we don't require the full python package.
IMHO I propose you ignore it. Or try/except it. We will be dropping PY2 as EOL after 0.19 release and I think the policy is to support PY2 "if its not too much trouble".
Question: Was documentation ever written for this functionality ? is it on the wiki ?
