how to read return values of Python commands
uwestoehr
Post by uwestoehr » Sun Oct 25, 2020 4:07 am
I want to read out properties of a feature using Python. For example I want to read the pitch of a helix. I can execute the right command:
cmd = QString::fromLatin1(
                "App.ActiveDocument.%1.Pitch\n")
                .arg(ObjectName);
Gui::Command::runCommand(Gui::Command::Doc, cmd);
But how do I get the return value so that I can do something with it in my C++ code?
uwestoehr
Re: how to read return values of Python commands
Post by uwestoehr » Sun Oct 25, 2020 2:01 pm
I failed to do this but found now a solution how to read out an object property the C++ way. This way I can use the return value directly.
Post by wmayer » Tue Oct 27, 2020 11:14 am
In terms of macro recording a line like
App.ActiveDocument.Helix.Pitch
is pointless anyway because the macro doesn't need it to be executed correctly. So, it's easier to get it via C++ instead.
Things would be different if you assign it to a variable and you want to get its content:
pitch = App.ActiveDocument.Helix.Pitch
This can be done with:
Py::Module module("__main__");
Py::Dict dict = module.getDict();
Py::Float pitch(dict.getItem("pitch"));
double value = static_cast<double>(pitch);
uwestoehr
Post by uwestoehr » Wed Oct 28, 2020 1:16 am
Many thanks. I'll use this for future and as reference.
I came across this while working on making it possible to edit Part's primitives via a dialog.
I found now a C++ solution to get the helix pitch:
App::Property* Property = docObj->getPropertyByName("Pitch");
App::PropertyQuantity* value = static_cast<const App::PropertyQuantity*>(Property);
and used this in the according PR: https://github.com/FreeCAD/FreeCAD/pull/4000
Besides this, is there a technical reason why there is no function to get a property quantity directly? (to have such a code instead to cast:
Property->getQuantity()
Who is online
Users browsing this forum: No registered users and 4 guests
