Scripting Path workbench
tcs_ulrich
Post by tcs_ulrich » Wed Jan 09, 2019 9:52 am
I want to generate G-code from an in Script created Object (an Plate with Text as Pocket).
But i find no Documentation how to generate the "Path Operation" and the "Profile based on Faces"
best regards
Christian
tcs_ulrich
Re: Scripting Path workbench
Post by tcs_ulrich » Fri Mar 20, 2020 9:42 am
Hi, in meantime ive get an patially working Solution in this German Thread: https://forum.freecadweb.org/viewtopic. ... 45#p378645
But i have at time no working Solution to Create an Tool definition and Assign Tools to Path Operations, has anyone an clue how that can be done in an python script ?
etrombly
Post by etrombly » Fri Mar 20, 2020 4:13 pm
This is how I create a PathCustom and assign it to a job and toolcontroller. You should be able to modify it to do what you need.
obj = FreeCAD.ActiveDocument.addObject("Path::FeaturePython", "Custom")
    PathScripts.PathCustom.ObjectCustom(obj)
    obj.ViewObject.Proxy = 0
    obj.Gcode = gcode
    PathScripts.PathUtils.addToJob(obj)
    obj.ToolController = PathScripts.PathUtils.findToolController(obj)
edit: This just assigns the first active tool. Not sure about creating a new one.
tcs_ulrich
Post by tcs_ulrich » Fri Mar 27, 2020 10:17 am
Ive found an solution i can Create an TC with
drill1mm = Path.Tool("1mm Endmill",tooltype="EndMill",diameter=1)
tc1mm = PathToolController.Create('drill1mm', tool=drill1mm)
And Assign with
FontCut.ToolController = tc1mm
Who is online
Users browsing this forum: Google [Bot] and 3 guests
