[solved] Value increase error: editing 3D Surface changes values all by itself
freman
Re: Value increase error: editing 3D Surface changes values all by itself
Post by freman » Sat Mar 28, 2020 7:39 pm
The PR I submitted was for BoundaryDressUp to allow negative values but it affected boundary code itself. It was not the cause of the bug but may be a clue if it is a new trigger. I suggested that, since there is a new flux of these reports and they mainly seem to refer to boundary in some way.
since 3D must use boundary, so that is not excluded.
Post by chrisb » Sat Mar 28, 2020 9:00 pm
chrisb wrote:
Sat Mar 28, 2020 6:38 pm
Do you have changes there too?
That was not clear. I didn't mean if you made changes to the code, I rather meant if you also see values change all by themselves in 3D surface dialog.
freman
Post by freman » Sun Mar 29, 2020 12:33 am
Thanks. As I wrote above I can not even reproduce this bug. Unlike you and others on Gnome/Ubuntu, I always get correct locale information from FreeCAD.
Correct locale detection may be pertinent to the bug. It would be useful to look at whether others reporting issues are getting correct locale. Using an AppImage maybe affect this.
herbk
Post by herbk » Sun Mar 29, 2020 8:01 am
Hi freman
thats not to search at Gnome/Ubuntu, because i'm at OpenSuse/KDE...
Gruß Herbert
freman
Post by freman » Sun Mar 29, 2020 10:10 am
Then maybe it would be useful to see what OpenSuse/KDE does when changing locale, as Chris did here:
https://forum.freecadweb.org/viewtopic. ... 30#p381501
As I said, I've seem reports that Gnome messes with locale settings which are done from command line and not via their GUI tool. It would be useful to know if KDE is better behaved. Since qt and KDE are from the same stable I would not expect conflicts here and any qt objects locale sniffing will probably accurate.
It would be generally useful, as well as for this bug, to know to what extent FC Help info is correctly reporting.
herbk
Post by herbk » Tue Apr 07, 2020 11:19 am
With the update FC AppImage 0.19.20406 the problem of the increasing values is gone for me, so i'l set the topic to solved:
Gruß Herbert
Russ4262
Post by Russ4262 » Tue Apr 07, 2020 6:40 pm
Alright!
Should anyone else experience this problem, or should it reoccur later, please report it.
Russ
Re: [solved] Value increase error: editing 3D Surface changes values all by itself
Post by chrisb » Tue Apr 07, 2020 8:12 pm
The auto value changes are fixed, but the BoundBox Extra Offset values are greyed aout and not editable at all.
OS: macOS High Sierra (10.13)
Version: 0.19.20406 (Git)
Hash: bb45a2b01f9aafeae00cdf60c87b43fc36ad28ad
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
Post by chrisb » Tue Apr 07, 2020 8:18 pm
Concerning the semi-responsive expression aware fields, which don't immediately show a changed value, I just realized that they worked in 0.18, but don't in 0.19. Perhaps it's a Qt thing? Should I open a new topic for this?
Ok in:
OS: macOS 10.13
Version: 0.18.16146 (Git)
Branch: (HEAD detached at 0.18.4)
Python version: 3.6.7
Qt version: 5.6.2
Not ok in the version from my previous post.
freman
Post by freman » Tue Apr 07, 2020 8:55 pm
That's more recent than 0.18, I've never used 0.18 and this probably came when I move my master build from qt4 to qt5.
If I had to say from memory, I'd say master in November was not doing this. IIRC that was about the time I swapped to QT5, so I'm not clear if it was qt, or a master change concurrent with my changing my build system .
Who is online
Users browsing this forum: No registered users and 3 guests
