How to set origin at specific location on my stock
RoCNC
Post by RoCNC » Wed Mar 25, 2020 1:53 pm
I want to set the origin exactly at the top and center of my stock material. But there is no reference at that point in my body. How I do that?
So far, with other parts, I only had to select a useful corner on my stock material and then click on "Set Origin".
But in this case in the center there is nothing to select....
OriginTopCenter.FCStd
(22.64 KiB) Downloaded 2 times
dubstar-04
Re: How to set origin at specific location on my stock
Post by dubstar-04 » Wed Mar 25, 2020 2:23 pm
One way you can do this is leave the origin at 0,0,0 and move the stock to the required position using any of the standard FreeCAD move tools.
Thanks,
Dan
RoCNC
Post by RoCNC » Wed Mar 25, 2020 3:42 pm
Thank you for your response Dan,
I played around with this and found the following solution (based on your tip):
1) select a corner of the stock and click set origin (just like normal)
2) move the stock with the Arrows by a handy distance (in my case 60mm)
3) select the stock corner that is now at the top center of the model-body and click set origin
4) click OK
5) double click on stock in the tree
5) now move the stock with the arrows back so that it fits around the model-body
6) click OK again
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
RatonLaveur
Post by RatonLaveur » Wed Mar 25, 2020 4:40 pm
Not that I've tried but could we set parametric datums (points/lines/planes) in the path workbench for usability?
Example: I'd like to run a probing cycle on my part. I set up datum points and vectors of approach and then can reference them in PathWB to output G-code.
Example: i want to machine my stock at different orientation, let's say with a 4th axis. By creating datum planes and i can reference a work plane to use for a specific 2.5D OP and another's workplane for the other.
Example: for 4th axis, i can define the axis of rotation by creating a datum line. And i can reference that with probing points.
Who is online
Users browsing this forum: herbk and 3 guests
