I will do a small series of quick, short, messages with my results so far.
The fixed model is already uploaded in a previous message and I will not repeat it here.
I keep the fixed model unchanged, not correcting the overshoot of the diamond at the four corners.
This (first) message includes the parameterised model. Again, I will not repeat that in every message.
The parameterised model has no overshoot, it has a perfect match of the diamond corners on the circle and square.
The advantage of using a spreadsheet with parameters and matching up points in the design.
On the inner circle pocket I got a result which is different between the two models and I cannot explain it.
First, on the 'fixed model' (unchanged, available in a previous upload) I get, what seems to me, an incomplete path.
On the parameterised model (see attached project) I do not get the same result. And I don't know why.
How to generate a path that I can envision but FreeCAT can not.
- PapaAtHome
Re: How to generate a path that I can envision but FreeCAT can not.
- Square-Circle-Diamond.v0.19.FCStd
- (51.54 KiB) Downloaded 17 times
Kind regards, Andre.
- PapaAtHome
What I want to archieve with the inner pocket is to only cut out one circle and not milling away the total of the pocket.
Grounds for this:
- If I cut out the circle it becomes detachted from the rest of the model, no need to do more.
- It saves time!
This is my (naive) idea of creating a path.
"I want to do an operation on a surface (or edge) and it is sufficient to select that surface (or edge)."
I assume that the bit is always touching the surface I selected. If the tool is not somehow touching the surface then it is doing something that is not part of the operation I want.
With my idea of a path there are two parts of the bit that counts, the tip and the side. For some selections only the tip can touch the surface and for some other selections only the side can touch the surface.
Here is an image of what I want. (Done on the fixed model, the picture shows what I want but the details are not matching up in total with my idea). The surface has a Z component and only the side of the bit can touch it.
This makes some of the patterns 'stange'. (Just proving that my idea of path operations is indeed naive and incomplete.)
What does 'line', 'grid' or 'triangle' mean for the surface I have selected?
Also, availabl in some operations but not in this example, what is the meaning of 'inside' and 'outside'?
The above image was produces with a 'Pocket mode' operation.
Again, it is difficult to match this operation with my idea of surface operation.
I guess that a 'Facing operation' is more apropriate here. (As in 'an operation on the facing that is selected' ).
But what is the meaning of all the patterns for the selected facing?
Also, none of the patterns stick to the surface only, all work on the pocket. Clearly, I have the wrong ideas about path operations.
Can anyboy explain, in short, how to look at this?
Grounds for this:
- It saves time!
Hi Andre,
you are using the option "Spiral" for path creation. If i remember right, Spiral is a bit bugy...
If you want to cut it out only (not remove the whole area), use Contour by Edge or Contour by Face instead of the Pocket OP. At the last 0.19 this contour OPs are combined at Profile entire Model. Just select the upper edge of the hole and click Profile entire Model.
Profile entire Modell.
All Pocket OPs of FC Path are made to remove all material.
Gruß Herbert
- PapaAtHome
On completely circumfencing the diamond and circle shape.
Done some testing on the parameterised model and it realy is easy and simple!
When you realise that you can limit the final depth.
Here is an unlimited example, cutting all the way through the circle and square.
And here is the limited case.
That is one problem down and I learned a new trick.
- PapaAtHome
As I'm working with the latest version of 0.19, this is a quick test.herbk wrote: ↑Sun May 17, 2020 11:32 am Hi Andre,
And it works as you suggested.
Second problem solved. And I learned another trick, never stop trying.
But I also feel like I should have asked this questiong a long time before.
With a few suggestions my problems are solved in less than a day while I've been struggling with it for month after month.
Thank you all.
Here is another proposal for your question 2:
If I reduce the radius of the cylinder by 1/100 (1/1000 would work probably too) I can create easyly a circle around diamond and cylinder using a profile operation. File is attached.
- Square-Circle-Diamond_cb.FCStd
- (25.77 KiB) Downloaded 21 times
- PapaAtHome
I can see your point, with the reduction the cylinder is just a fraction smaller than the square and so is the diamond to the cylinder.chrisb wrote: ↑Sun May 17, 2020 8:39 pm Here is another proposal for your question 2:
If I reduce the radius of the cylinder by 1/100 (1/1000 would work probably too) I can create easyly a circle around diamond and cylinder using a profile operation. File is attached.Snip macro screenshot-63a28f.png
If the fraction is less than the machine precission you would not notice the differencent at all. Nice.
With the parameterised version I have a perfect match for both cylinder and diamond (to the square) and no dificulties in creatting a path around it. But I have to look out for the depth of the path(s). (I did not check it that is a requirement in your solution.)
Thanks for the idea. To me it looks like there is more than one solution to the problem.
