Using the PATH WB and Adaptive processing not releasing memory. Repeating the PostProcessing into a GRBL file increases
Re: Using the PATH WB and Adaptive processing not releasing memory. Repeating the PostProcessing into a GRBL file increa
hi user1234. I did indeed try this before with no difference.
Just now I tried again but no luck.
Both the tick box OFF and number at 0
But thx for bringing up the idea.
in my mind that's a workaround, but can't be accepted as a solution....
Gruß Herbert
It isn't even a workaround as it doesn't help anyway
Can this come from Python? I don't think so. Or is this from an underlying library? I hope not!
I think I'm a bit further down the line.
In the "grbl_post.py" you can find ;
# Parse the op
gcode += parse(obj)
Commenting this seems to fix the Memory issue.
Off-course no GRBL is written out to the file, but it seems somehow related to this step.
parse is an function in the same grbl_post.py
# Parse the op
gcode += parse(obj)
I don't think that shows anything important. Clearly if you do not process the g-code it should not cause memory usage.
There is nothing evil about the term "parse"; it is just the name of the function that creates the g-code. It could be called anything.
I tried the same experiment with linuxcnc_post.py, and the results were similar. (Parse is also used in linuxcnc_post.py.)
Gene
Gene
I'm far from being a Python expert but do have some scripting background.
It shows that up to this point no memory is taken by the code executed earlier.
The approach I took here is to see when the memory start creeping up.
Which module/script it is happening in.
I understand that the complete g-code code (whatever the size is going to be) is generated in memory.
After is has been generated the output is saved in a file.
One would expect that after saving the file the memory could be freed.
Also weird that a during the generation of the gcode file of several Mbytes, it takes Gbytes in Memory.
I assume the different gcode post processors (grbl - linuxcnc- etc) are based on a template. So they behave the same.
I'll dig further...
I'll dig further...
That should reveal where the culprit is. Hopefully it can be fixed and is not inside of an external library.
I think I suggested about a year ago someone should be doing leakage testing on FreeCAD ( my usage is mostly Part Design + PathWB. )
My mobo only supports 4GB of RAM and after a while my whole system gets very slow to change windows / desktops and generally gets sluggish. Looks a lot like disk trashing swap files as RAM dries up.
I've made some progress.
The attached code is modified version of the std. grbl_post.py PostProcessor. This a a very dirty quick fix. No cleanup done.
This was a trail&error approach as I'm not an Python expert.
Can someone please test this a confirm my findings. Use it at your own risk.
In my case it results in a memory saving of approx. 2GB - 0,2MB = 1,8GB per run of the PostProcessor
Exising grbl_post.py uses up to approx. 2GB on my model when PostProcessing to a GRBL file
The modified code grbljcl_post.py uses up to approx. 200MB on the same model when PostProcessing to a GRBL file.
Still 200MB to go but no clue yet.
No difference was found between the 2 output files using unix's : diff
(Except for the timestamp and the postprocessor name which are in the output file)
Looking forward to response from others with the same findings.
- grbljcl_post.py
- (22.78 KiB) Downloaded 52 times
