Ticket #4433 - profile operation cut side reset
Re: profile operation cut side reset
I basically agree with herbk; I don't see a need.
I am curious, however. Why are you deleting everything? Is this due to a user mistake or is it a modeling strategy for cycling through the generation of multiple paths?
Gene
Gene
I can well think of a not too artificial use case with several pockets, where you have erroneously created a profile for one pocket while it should have been for another. It is legitimate to expect that all parameters stay the same - heights, depths, tool, direction - so why not the cutting side.
I don't see this really as an error, but it may be worth a feature request.
Example: There are a bunch of static rigging holes, some of which need to be milled out depending on a pallet setup. Everything is setup in a freecad document. So document is loaded, OP that drills rigging holes is selected and needed holes are selected. At this point, cut side is automatically reset to"outside".
these here caused several bad mills for me already.
Pretty sure this is a bug and should be fixed.
I find this problematic, or at least the variation I have run into.
I was using contours to generate chamfer operations, which required me to disable the "use compensation", which then removes the "In/Out" field from the operations-tab. Because of the quirkiness of setting up the extra-offset, I had to select/deselect the "use compensation" button, which then resets the field.
This issue would benefit from not adding/removing the In/Out variable, depending on the "Use compensation" checkbox.
And, I noticed CW/CCW seemed wrong while milling yesterday, and so following up on it, I notice that it's inverted if "Use Compensation is deselected".
Re: Ticket #4433 - profile operation cut side reset
Mod Edit: Added ticket number to thread title
Russ4262 wrote: ↑Sat Sep 12, 2020 5:29 am PR #3861: [Path] Fixes #4433 - `Cut Side` reset with certain Base Geometry changes
Thanks a bunch.
