FEM crash when trying to write calculix input file
Re: FEM crash when trying to write calculix input file
Today night I improved the abaqus import to get more or less the same output as this reference application.
Currently the volume types C3D4 and C3D10 are supported: https://github.com/FreeCAD/FreeCAD_sf_m ... 747ee4f35b
Wow cool thanks for adding support for the C3D4 elements. Something is wrong with the node order. Don't askt me why. As Juergen stated in the code before "// neuer Versuch"
Attached the changes for C3D4 and C3D10 which gone work with current FreeCAD-CalculiX for me. The files provided in earlier posts run with this code.
branch:
https://github.com/berndhahnebach/FreeC ... riteabaqus
commit:
https://github.com/berndhahnebach/FreeC ... 84c5cd3e3d
branch:
commit:
When you visit the Salome forum from the given link you'll find the source for a program to convert from UNV to INP files. The source code includes everything it needs, i.e. no 3rd party library.Wow cool thanks for adding support for the C3D4 elements. Something is wrong with the node order. Don't askt me why. As Juergen stated in the code before "// neuer Versuch"
So, as reference I used the output of the created inp files. What actually happens when the order is different?
Further question:
From the source code there exists these types:
Volume: C3D4, C3D6, C3D8, C3D10, C3D15, C3D20
Faces: S3, S6, S4R, S8R
Edges: B31, B32
Do you have some examples of UNV files and their corresponding INP files with the above element types?
Can you try the latest changes again?
both C3D4 and C3D10wmayer wrote:Can you try the latest changes again?
What did you do according node order? There are lots of changes inside writeAbaqus?
I changed the code to easily add support for further volume/face/edge types.What did you do according node order? There are lots of changes inside writeAbaqus?
Wow, that looks great. We'll just a few steps away from supporting all these elements types
If I have a minute I'll try to create meshes and get the right node orders for writeAbaqus() for exporting !wmayer wrote:...
Edges: B31, B32
There are basically two information I need:
* the order of the element types
* Should be "ELSET" written out for faces/edges and if yes is its value also "Eall"
From the link you posted earlier there were mentioned elements like F3D4, ... which are called "fluid" elements. Do we have to support them, too?
Played a bit with 8-node hexahedron (C3D8) and was able to export to CalculiX and make a calculation. Thanks to your comments in FemMesh.cpp it is easy to release new Elements !
I created the mesh py hand in python. But what I found was writeAbaqus() uses the node order provided be the mesh software (means in my case by my hand ...) Means the node order is something which relies on the mesh software?! Do they use all the same standard ? I'm gone try to test with netgen and gmsh.
Made some tests with gsmh. A Problem raised. Find attached a file which includes C3D4, C3D10 (both work fine allready), S3, S6, B31 and B32 FemMeshes. I attached the unv-files as well. The 1D and 2D meshs have no ViewProvider. All meshes could be used to make a MechanicalAnalysis. Since we have Support for Edge- and Vertexloads and -fixes a MechanicalAalysis could be created and the Calculix file be written. The Calculix file needs to be edited to run smoothly (which works great using brand new syntax highligter in FreeCAD.
needs adaptions. The result file gets read and the min-, max, values are displayed. So everything looks great. We just need to define all the 1D and 2D stuff in MechanicalAnalysis later on.
Long speach short what's the problem:
see commit https://github.com/berndhahnebach/FreeC ... aed9166d18
If a C3D4 or C3D10 is written by writeAbaqus() all S3, S6 and B31 and B32 elements are written as well but they do not need to be written. Same for S3 an S6. If they are written by writeAbaqus() B31 and B32 elements are written as well. This seams due to a C3D4 volume element consits of faces and edges in the mesh but they should not be written as elements. Only the hightest "shape degree" shoud be written as element type by writeAbaqus().
My C++ is to smal to fix this.
*BOUNDARY
and
*SOLID SECTION, Elset=Eall, Material=CalculiX
- Cube-Plane-Line--FEM-Mesh.zip
- (298.05 KiB) Downloaded 78 times
