FEM Python coding standard
Re: OpenSees, the Open System for Earthquake Engineering Simulation
Post by Kunda1 » Wed Mar 25, 2020 11:10 pm
ebrahim raeyat wrote:
Wed Mar 25, 2020 10:08 pm
@bernd, when i type codespell -L:
codespell: error: no such option: -L
 -L WORDS, --ignore-words-list WORDS
                        Comma separated list of words to be ignored by
                        codespell. Words are case sensitive based on how they
                        are written in the dictionary file
From codespell --help
ebrahim raeyat
Re: FEM Python coding standard
Post by ebrahim raeyat » Wed Mar 25, 2020 11:15 pm
Kunda1 wrote:
Thu Sep 12, 2019 8:59 pm
when i type this command with -L flag, it takes me this error:
Usage:
	codespell [OPTIONS] [file1 file2 ... fileN]
codespell version 1.8
Post by Kunda1 » Wed Mar 25, 2020 11:21 pm
$ codespell --version
1.17.0.dev0
Check out https://github.com/codespell-project/codespell#updating
ebrahim raeyat
Post by ebrahim raeyat » Wed Mar 25, 2020 11:48 pm
1.17.0.dev0
thanks, it works.
ebrahim raeyat
Post by ebrahim raeyat » Thu Mar 26, 2020 8:36 am
bernd wrote:
Thu Mar 26, 2020 5:34 am
double posted! Is solved here https://forum.freecadweb.org/viewtopic. ... 70#p380760
yes, i prefer to solve this in related topic. if you can please move those to related topic. thanks.
vanuan
Post by vanuan » Fri Aug 28, 2020 1:31 pm
bernd
Post by bernd » Fri Aug 28, 2020 2:22 pm
are they conform with FEM conding standards? See https://github.com/FreeCAD/FreeCAD/blob ... entions.md
vanuan
Post by vanuan » Fri Aug 28, 2020 3:22 pm
Have you read the proposal? It mainly focuses on a method to enforce those. But yeah, the first rules I propose to enable are the snake_case naming and the import grouping which are included in the document you referenced.
Does FEM already use flake8?
bernd
Post by bernd » Fri Aug 28, 2020 4:04 pm
the document I referenced only has coding standards which are fulfilled by FEM python code already. I only add new coding standard if at least the most code of FEM does use the coding standard. Thus there is only rare coding standard for FEM C++ code, since I do not do that much c++ code and thus I do not change the coding standard.
bernd
Post by bernd » Fri Aug 28, 2020 4:06 pm
AFAIK FEM and Draft uses flake8. Only difference is the indent. Draft uses other indent style as FEM.
vocx might give some more information in this regard.
vocx wrote: :bell:
Who is online
Users browsing this forum: No registered users and 3 guests
