FEM - Dynamic Loads?
JensElmo
Post by JensElmo » Fri May 18, 2018 8:29 am
I have a project where I have essentially a mechanical hammer hitting object with a down force of 160kN in a percussion rate of 32 Hz.
I am not able to find out how in the FEM module to apply a dynamic load, if that is even possible in FreeCAD.
So I was hoping somebody could help me, or direct me to a tutorial about dynamic loads.
FreeCAD Info
Version: 0.17.13387 (Git)
Hash: c5f4079252b11e3c54cd603be7d3697fa9f9d922
Python version: 2.7.14
OCC version: 7.1.0
Locale: Danish/Denmark (da_DK)
Jee-Bee
Re: FEM - Dynamic Loads?
Post by Jee-Bee » Fri May 18, 2018 11:33 am
You have to modify you're input file of calculix.
you need at least add the *AMPLITUDE parameter.
see for a bit more information http://www.feacluster.com/CalculiX/ccx_ ... de202.html
I'm not sure what type of analysis you need. just start with *STATIC and try out..
HarryvL
Post by HarryvL » Fri May 18, 2018 1:57 pm
@Jee-Bee, the simplest analysis type that captures steady state dynamic response is "Steady State Dynamic Analysis, as I use and describe here:
https://forum.freecadweb.org/viewtopic. ... 50#p232309
However this assumes a sinusoidal periodic load. If you have a different periodic load then you would need Fourier analysis to write this as a sum of periodic loads. I believe there is an option for that too in CCX. However, I would first try to use the simplest option (above) and see if you can make that work.
HarryvL
Post by HarryvL » Fri May 18, 2018 2:05 pm
I just checked the manual. CCX can indeed decompose a general periodic load into sinusoidal (harmonic) components using Fourier transform. The only additional thing you need to do (in addition to what I describe above and in my bridge post) is to add HARMONIC=NO to the *STEADY STATE DYNAMICS card and describe one period of the load in the *AMPLITUDE card. It will produce similar results as in my post, so please take care with the post processing. I would be interested to see your results.
Jee-Bee
Post by Jee-Bee » Fri May 18, 2018 3:12 pm
Sorry @HarryvL i just read sometimes parts of of the CCX documentations but it takes time to gain some experience
JensElmo
Post by JensElmo » Mon May 28, 2018 8:31 am
Sorry I am late replying, have been ill.
I am relativly new to FreeCad and have no experience in Python, so i have possible misunderstood the post on Steady State Dynamic Analysis. So would like to check if I understood it correctly.
What I understood and did was make a simple part to test on before moving on to my actual part.
Then on my simple test part I set up a FEM study ( Chose material, Contraints, Force and Mesh) , Then ran the solver and edited the file to replace the 'Static Step' with the 'Steady State Dynamics Step' you wrote in the bridge thread.
It gives an error message : "*ERROR in steadystate: cannot open eigenvalue file for reading", but still says that it is done and opening results but never does.
(See below for complete message)
0.0: Check dependencies...
0.1: Write completed.
0.0: CalculiX binary: C:/Program Files/FreeCAD_0.17.13387_x64_dev_win/bin/ccx.exe
0.0: Run CalculiX...
0.0: Starting CalculiX...
0.0: CalculiX is running...
0.2: CalculiX stopped.
0.2: ************************************************************
CalculiX Version 2.12, Copyright(C) 1998-2015 Guido Dhondt
CalculiX comes with ABSOLUTELY NO WARRANTY. This is free
software, and you are welcome to redistribute it under
certain conditions, see gpl.htm
You are using an executable made on Tue, Apr 4, 2017 11:04:04 PM
The numbers below are estimated upper bounds
number of:
nodes: 1792
elements: 1489
one-dimensional elements: 0
two-dimensional elements: 0
integration points per element: 4
degrees of freedom per node: 3
layers per element: 1
distributed facial loads: 0
distributed volumetric loads: 0
concentrated loads: 62
single point constraints: 198
multiple point constraints: 1
terms in all multiple point constraints: 1
tie constraints: 0
dependent nodes tied by cyclic constraints: 0
dependent nodes in pre-tension constraints: 0
sets: 5
terms in all sets: 6155
materials: 1
constants per material and temperature: 2
temperature points per material: 1
plastic data points per material: 0
orientations: 0
amplitudes: 2
data points in all amplitudes: 2
print requests: 2
transformations: 0
property cards: 0
STEP 1
Decascading the MPC's
Determining the structure of the matrix:
number of equations
5178
number of nonzero lower triangular matrix elements
165792
Composing the steady state response from the eigenmodes
0.2: CalculiX done!
0.3: Loading result sets...
I have attached my test part, but that is just a basic part made to see if I could get it to work.
Test - Dynamic.FCStd
(105.13 KiB) Downloaded 30 times
Jee-Bee
Post by Jee-Bee » Mon May 28, 2018 8:52 am
Can you add you're inp file? with out it we can't see what you changed...
flachyjoe
Post by flachyjoe » Mon May 28, 2018 9:36 am
the *STEADY STATE DYNAMIC step need eigenmodes and eigenfrequencies calculation, these are gave by a *FREQUENCY, STORAGE=YES step.
See : http://web.mit.edu/calculix_v2.7/Calcul ... de244.html
For the Frequency step, same boundary conditions as for the steady state step are needed.
- Flachy Joe -
alias FFW @ irc.freenode.net #freecad et #freecad-fr
"Puisqu’on ne peut changer la direction du vent, il faut apprendre à orienter les voiles." Anonyme
HarryvL
Post by HarryvL » Mon May 28, 2018 9:46 am
Indeed, you need 2 steps, for example:
** step 1
*STEP
10,0.0,1000000.0
** BOUNDARY cards
*NODE FILE, OUTPUT=2d
U
**EL FILE
**S, E
**NODE PRINT , NSET=Nall
**U
**EL PRINT , ELSET=Eall
**S
*END STEP
** step 2
*STEP
0., 5.
** CLOAD/DLOAD cards
*MODAL DAMPING
1,10,0.1
U
**EL FILE
**S, E
*NODE PRINT , NSET=Output
U
**S
*END STEP
EDIT: no need for a DLOAD/CLOAD card in the first step.
JensElmo
Post by JensElmo » Mon May 28, 2018 10:15 am
Oh, yes of course, the attachment wonøt let me attach an inp file, so i zipped it
FEMMeshNetgen.zip
(57.74 KiB) Downloaded 33 times
Who is online
Users browsing this forum: No registered users and 1 guest
