Re: OOFem
Posted: Sat Sep 26, 2020 12:00 pm
FTFYbernd wrote: ↑Sat Sep 26, 2020 12:00 pm https://github.com/berndhahnebach/FreeC ... tress2D.in
line 18
I did not compile and test the oofem branch for a long time. Just pushed some fixes. Unit tests and examples set up again.bernd wrote: ↑Fri Sep 25, 2020 7:00 pm very good news.
There are some examples. These should give results.
- https://github.com/berndhahnebach/FreeC ... s2d.py#L30 and
- and the standard ccx cantilever
- a unit test can be run. see https://github.com/berndhahnebach/FreeC ... #L166-L169 the commands to set up the example can be found in the module test_solver_oofem.py the FreeCAD files will be save in tmp folder
https://github.com/berndhahnebach/FreeC ... a26052a120bernd wrote: ↑Fri Sep 25, 2020 7:08 pmwould you make a PR to https://github.com/berndhahnebach/FreeC ... s/femoofemnitramkaroh wrote: ↑Fri Sep 25, 2020 12:35 pm ... I got just one error when trying to run OOFEM, the error was related to time.clock() (in writer.py) since I am using python 3.8.2; that was an easy fix. ...
Thanks. All good.
