FEM anaylsis of GDML Designs.
bernd
Re: FEM anaylsis of GDML Designs.
Post by bernd » Sat Sep 21, 2019 6:53 am
does it work for you on a simple part box?
boxmesh.FCStd
(93.68 KiB) Downloaded 14 times
keithsloan52
Post by keithsloan52 » Sat Sep 21, 2019 7:59 am
bernd wrote:
Sat Sep 21, 2019 6:51 am
keithsloan52 wrote:
Sat Sep 21, 2019 5:52 am
Okay I tried to see if I creating a Mesh for a simple GDML Object i.e. implemented as a FreeCAD Python Object.
When in FEM workbench. Have it selected then click on Mesh icon window pops up with Apply | Cancel | OK
but before I get to try Apply I get a message in Report View
Fem::FemMeshObjectPython / FEMMeshGmsh: Links go out of the allowed scope
If I try Apply I get
0.0: We are going to start ...
0.0: Start Gmsh ...
1.0: Clean run of Gmsh
1.0: Gmsh done!
But No mesh created as far as I can tell
Using Check Geometry in Part Workbench gives
1 processed out of 1 selecfed
0 invalid shapes
would you post the FreeCAD file with that object ?
Attached is the FreeCAD file, but not sure you will be able to do much with it without installing the Workbench
https://github.com/KeithSloan/FreeCAD_Python_GDML
test.FCStd
(9.7 KiB) Downloaded 19 times
The imported GDML file is g4box.gdml in the SampleFiles directory see github.
(This forum does not allow upload of files with the gdml extension).
bernd
Post by bernd » Sat Sep 21, 2019 11:47 am
just add .txt and you can upload any file
keithsloan52
Post by keithsloan52 » Sat Sep 21, 2019 6:37 pm
Not sure what has changed but I still get the message, but it does now create a Mesh.
I will experiment to see if I can reproduce the problem again.
What is the situation with Compounds of different materials, can one still do FEM analysis on them ?
How does one specify the material of each object? All the GDML solids have a material definition but it is very
different from FEM's. Can I allocate a material under program control?
keithsloan52
Post by keithsloan52 » Sun Sep 22, 2019 12:18 am
Hi @bernd I see from the tutorial https://www.freecadweb.org/wiki/FEM_Tutorial_Python It is possible to define materials and allocate to an object. Do you have a pointer to a full list of material parameters? Also just the materials associated with heat transfer.
Thanks
keithsloan52
Post by keithsloan52 » Sun Sep 22, 2019 10:18 am
Okay I have had a go at adding materials and thermal properties but am not sure how I can check if it worked.
Get the impression that the values have not been set.
testA.FCStd
(13.98 KiB) Downloaded 15 times
Coding print(mat) in the code outputs
{'Name': 'SSteel0x56070ee87d10', 'Density': '1.0 kg/m^3', 'ThermalConductivity': '2.0 W/m/K', 'ThermalExpansionCoefficent': '3.0 m/m/K', 'SpecficHeat': '4.0 J/kg/K'}
Also why on the second file has it add 001 to the solid names as far as I know they are unique, but maybe a bug in my code.
testB.FCStd
(17.47 KiB) Downloaded 24 times
print("Found Material")
matObj = ObjectsFem.makeMaterialSolid(doc, material)
mat = matObj.Material
mat['Name'] = material
mat['Density'] = str(n.density) + " kg/m^3"
mat['ThermalConductivity'] = str(n.conduct) + " W/m/K"
mat['ThermalExpansionCoefficent'] = str(n.expand) + " m/m/K"
mat['SpecficHeat'] = str(n.specfic) + " J/kg/K"
print(mat)
matObj.Material = mat
analObj.addObject(matObj)
keithsloan52
Post by keithsloan52 » Sun Sep 22, 2019 10:38 am
Okay I see I need to double click the material to bring up the editor.
bernd
Post by bernd » Sun Sep 22, 2019 1:09 pm
multi material tutorial FEM_Shear_of_a_Composite_Block
Who is online
Users browsing this forum: No registered users and 2 guests
