FEM regions restrictions depends of order in tree
Adel Chepkunov
Post by Adel Chepkunov » Thu Dec 26, 2019 2:23 pm
Hello, all.
I found a very inconvenient behavior. If I make mesh for some CompoundFilter object and set max element size for two neighboard regions then result depend of order of regions. If maxsize for second region more then max size for first region, then size of lements in first region near boundar will be more then limit for first region.
It will be not awful, if I can change order in tree. If I wand add new region, I should delete many count of regions before and add ones again after.
But it will be better if the order will does not matter.
BTW, for add region by hotkeys ("M, G"), I should click to mesh even if another region selected in this mesh. It is non convenient also.
BR,
Adel
UR_
Re: FEM regions restrictions depends of order in tree
Post by UR_ » Thu Dec 26, 2019 4:48 pm
If mesh regions are direct neighbors with sharing edge and therefore sharing vertexes, the later declared region has right-of-way.
From inner rectangles the right one is declared later.
Screenshot 001.png (69.92 KiB) Viewed 295 times
If they don't touch, so they don't share vertexes, mesh refinements are independently
Screenshot 004.png (41.84 KiB) Viewed 295 times
fandaL
Post by fandaL » Thu Dec 26, 2019 7:36 pm
Partial help is to drug MeshRegion object and drop it to the parent mesh object, so that it is inserted as a last child.
Adel Chepkunov
Post by Adel Chepkunov » Fri Dec 27, 2019 12:47 pm
Yes, it is. But I want mesh whick like to mesh in up-left corner more then mesh in left-down corner. So, I get mesh like mesh in up-right corner from time to time.
Adel Chepkunov
Post by Adel Chepkunov » Fri Dec 27, 2019 12:48 pm
May be. I'll try to do it. Thank you!
Post by bernd » Sat Dec 28, 2019 10:01 am
@Adel:
do you have an example file to reproduce the problem.
@_UR:
would be cool to have your great explanation somewhere in the wiki.
Post by bernd » Sun Jan 05, 2020 9:26 pm
Is this a problem we should solve or is this a problem the user should be aware of because it is meshing knowledge?
Post by bernd » Sun Jan 05, 2020 9:31 pm
later declared means the later declared in gmsh geofile. I wonder if later in tree in any case means later in geo file. The one who should know this is me ... :shock:
Post by bernd » Sun Jan 05, 2020 9:46 pm
Yes it should be this way. The tree shows the order the same way the list is declared in the mesh region property of the parents mesh. To get the region in geo file it will be itereated over this list. Thus:
this changes order in tree and oder in mesh region list of parent mesh. Thus this should do the trick.
Would be good to have some feedback.
Who is online
Users browsing this forum: HoWil and 4 guests
