shell to shell contact
thschrader
Post by thschrader » Mon Jan 06, 2020 1:59 pm
want to calculate the contact between 2 cylinders using 2D shell-elements as described here
https://www.youtube.com/watch?v=cH_leTeGBuA
After writing the case the …contact.inp is empty (see picture). Maybe I do something wrong.
cylinder_contact_2D.FCStd
(13.8 KiB) Downloaded 7 times
3D-case works
cylinder_contact_3D.FCStd
(14.89 KiB) Downloaded 7 times
In the end I want to calculate flange to flange contact with 2D-elements and a plastic material like these guys are doing:
https://www.ideastatica.com/steel/
flange_2D.FCStd
(57.78 KiB) Downloaded 6 times
system:
Version: 0.18.15860 (Git)
Hash: 3b708c7f84b0425076b520e1d95627b20fd75fe0
Python version: 2.7.14
OCC version: 7.2.0
UR_
Re: shell to shell contact
Post by UR_ » Thu Jan 09, 2020 9:34 am
You are right, shell to shell contact is a must have ;)
Unfortunately input writer doesn't support non solid elements ATM
src\Mod\Fem\femsolver\calculix\writer.py line 610
                        f.write("*SURFACE, NAME =" + name + "\n")
                        v = self.mesh_object.FemMesh.getccxVolumesByFace(ref_shape)
                        for i in v:
                            f.write("{},S{}\n".format(i[0], i[1]))
user manual ccx 2.16 page 543, 544 says:
for quadrilateral shell element
• Face NEG or 1: in negative
• Face POS or 2: in positive
• Face 3: 1-2
• Face 4: 2-3
• Face 5: 3-4
• Face 6: 4-1
for triangular shell elements:
• Face NEG or 1: in negative normal direction
• Face POS or 2: in positive normal direction
• Face 3: 1-2
• Face 4: 2-3
• Face 5: 3-1
Perhaps restriction to POS should be sufficient.
NEG sides aren't selectable by task panel of contact constraint.
UR_
Post by UR_ » Thu Jan 09, 2020 10:24 am
Screenshot 001.png (238.24 KiB) Viewed 331 times
Screenshot 002.png (17.5 KiB) Viewed 331 times
:roll:
expected results?
dirty proof:
                        #v = self.mesh_object.FemMesh.getccxVolumesByFace(ref_shape)
                        #for i in v:
                        #    f.write("{},S{}\n".format(i[0], i[1]))
                        v = self.mesh_object.FemMesh.getFacesByFace(ref_shape)
                        for i in v:
                            f.write("{},S2\n".format(i))
UR_
Post by UR_ » Fri Jan 10, 2020 7:12 pm
bernd wrote: :bell:
A little patch for src/Mod/Fem/femsolver/calculix/writer.py
to get shell meshes covered.
line 611:
                        if len(v) > 0:
                            # volume elements found
                            FreeCAD.Console.PrintLog(
                                "{}, surface {}, {} touching volume elements found\n"
                                .format(contact_obj.Label, name, len(v))
                            for i in v:
                        else:
                            # try shell elements
                            if len(v) > 0:
                                    "{}, surface {}, {} touching shell elements found\n"
                                for i in v:
                            else:
                                FreeCAD.Console.PrintError(
                                    "{}, surface {}, Error: Neither volume nor shell elements found!\n"
                                    .format(contact_obj.Label, name)
writer.py.diff.zip
(662 Bytes) Downloaded 2 times
modified file (if diff doesn't work)
writer.py
(89.67 KiB) Downloaded 3 times
A little test file made from shell elements:
Screenshot 004.png (156.5 KiB) Viewed 294 times
TubeTube-stripped.FCStd
(19.97 KiB) Downloaded 5 times
What's your opinion about this :?
bernd
Post by bernd » Fri Jan 10, 2020 7:41 pm
If you continue to make such cool contributions I do not care if you use git or not. But it would make things easier even for you! :ugeek:
I will have a look on the weekend ...
cheers bernd
UR_
Post by UR_ » Fri Jan 10, 2020 7:57 pm
... even for you!
Hope there is a tutorial out there, howto get things done :shock:
bernd
Post by bernd » Fri Jan 10, 2020 8:04 pm
FreeCAD helps with everything ... :mrgreen: Source_code_management
bernd
Post by bernd » Fri Jan 10, 2020 8:07 pm
The short version ...
create a github account, fork FreeCAD, clone this repo to your local pc, make a new branch shellcontact on your local repo, copy the code (writer.py file), make a commit, push the new branch from your local repo to github and post the address here. If you encounter any problems ask.
UR_
Post by UR_ » Mon Jan 13, 2020 5:19 pm
Hope this works.
https://github.com/FreeCAD/FreeCAD/pull/2892
Please have a look.
bernd
Post by bernd » Mon Jan 13, 2020 5:33 pm
It would be possible to have a face with shell elements and one with tetras. FreeCAD would ust write it to file. Does this makes sense for FEM analyse point of view and does ccx can handle this case?
Who is online
Users browsing this forum: Bing [Bot] and 4 guests
