gmsh does not mesh a half cylinder as I would expect it
Post by bernd » Sun Feb 02, 2020 2:06 pm
anyone an idea why gmsh has huge problems to mesh this ... ?
cheers bernd
halfcylinder.FCStd
(90.65 KiB) Downloaded 7 times
fandaL
Re: gmsh does not mesh a half cylinder as I would expect it
Post by fandaL » Mon Feb 03, 2020 7:01 am
I have no problems with the file. Recreated mesh is uniform.
OS: Linux Mint 19.3 (MATE/mate)
Version: 0.19.19443 (Git) AppImage
Hash: 74680b8a15ad37e53eee0d341e95cd32631d88a3
Python version: 3.8.1
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
UR_
Post by UR_ » Mon Feb 03, 2020 8:39 am
gmsh 4.5.2 on win 10 has no problems too.
For general remark:
To improve model's stability, you should avoid touching seams.
In your example file, please have a look at cylinder's seam in relation to box's top face
Screenshot 003.png (11.04 KiB) Viewed 219 times
Jee-Bee
Post by Jee-Bee » Mon Feb 03, 2020 10:04 am
same as bernd on pre compiled version
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18719 (Git)
Hash: c021ff70debb106b27d03ed1707f4b05fcf385a6
Python version: 3.6.7
Qt version: 5.12.1
2020-02-03 11_02_44-FreeCAD 0.19.png (44.81 KiB) Viewed 209 times
Post by bernd » Mon Feb 03, 2020 1:38 pm
same problem on win dev builds They have gmsh 4.2.1.
For general remark:
if the cylinder is rotated the problem is gone.
But:
Eventually I would like to remesh this with gmsh: https://github.com/FreeCAD/FreeCAD/blob ... d_solid.py
If in there this line https://github.com/FreeCAD/FreeCAD/blob ... lid.py#L74 is changed to:
        Rotation(90, 0, 90),
the line in the cylinder is rotated as _UR requests, but eventually the fusion has again problems with meshing ... I may should give the newer versions of gmsh a try too.
Post by bernd » Mon Feb 03, 2020 1:40 pm
BTW: If compound filter and again compound is used on the initial file, nothing on the shape seams changed, but gmsh meshs the halfcylinder without any problems.
UR_
Post by UR_ » Mon Feb 03, 2020 10:23 pm
But:
I had a short look at your script.
To make a bar with half of circle crossection, attached code snippet looks a little bit simpler:
top_cylinder_obj = App.ActiveDocument.addObject("Part::Cylinder", "BottomCylinder")
top_cylinder_obj.Radius = 30
top_cylinder_obj.Height = 500
top_cylinder_obj.Angle = 180
shape = Part.getShape (top_cylinder_obj, '', needSubElement = False, refine = True)
top_cylinder_obj.Shape = shape
No box and no boolean are needed.
Post by bernd » Tue Feb 04, 2020 7:46 am
https://github.com/berndhahnebach/FreeC ... 5c3f7996f2 It does make geometry creation much simpler, but the gmsh mesh problem keeps alive.
Post by bernd » Tue Feb 04, 2020 9:49 am
since it simplifies geometry creation I merged it into master anyway git commit f5835dc
Who is online
Users browsing this forum: Chris_G and 2 guests
