Cancel handling issue with FEM constraint dialogs
Site Admin
Re: Cancel handling issue with FEM constraint dialogs
Post by wmayer » Thu Aug 27, 2020 3:47 pm
Here is a simplified example of a task dialog in Python:
class TaskDialog:
  def __init__(self, doc):
    self.doc = doc
    doc.openTransaction("Add object")
    doc.addObject("Part::Box", "Box")
    doc.recompute()
  def accept(self):
    print ("Accept")
    self.doc.commitTransaction()
    return True
  def reject(self):
    print ("Reject")
    self.doc.abortTransaction()
    return True
Gui.Control.showDialog(TaskDialog(App.ActiveDocument))
When opening the dialog it opens a transaction and adds a box. If you press OK the transaction will be committed and the box stays, while when pressing Cancel the box will be removed again.
Here is a version using setActiveTransaction and closeActiveTransaction.
class TaskDialog:
    self.doc = doc
    FreeCAD.setActiveTransaction("Add object")
    doc.recompute()
  def accept(self):
    print ("Accept")
    FreeCAD.closeActiveTransaction()
    return True
  def reject(self):
    print ("Reject")
    FreeCAD.closeActiveTransaction(True)
    return True
bernd
Post by bernd » Thu Aug 27, 2020 6:02 pm
just to be sure ...
ATM in FEM C++ the objects are added in command.cpp in the specific commsnd class. In FEM Pythen the objects are added in the command class not in the task panel class.
In your exsmples the objects are added in the task panel class. But how do I start the task panel than? ATM the objects are added in the command class and the new object is set in edit modd an thus the task panel is opened.
bernd
Post by bernd » Thu Aug 27, 2020 6:41 pm
ahh found it ... the showDialog method is used to start the task panel.
Post by Kunda1 » Thu Aug 27, 2020 6:45 pm
bernd wrote:
Thu Aug 27, 2020 10:29 am
$ grep -r "closeActiveTransaction(True)"
Try
grep -iRn "closeActiveTransaction(True)"
bernd
Post by bernd » Fri Aug 28, 2020 4:13 am
Try
Jee-Bee
Post by Jee-Bee » Fri Aug 28, 2020 9:49 am
Thanks @ bernd for you work
Post by Kunda1 » Fri Aug 28, 2020 11:28 am
;) :D
Who is online
Users browsing this forum: No registered users and 4 guests
