Did you double check the results with calculix and the calculation from the paper in the bimetall topic.Sudhanshu wrote: ↑Wed Jul 29, 2020 9:21 amTests for elmer examples, including thermomech bimetall: https://github.com/Sudhanshu-Dubey14/Fr ... d7fcc617c2
They are all in standard FreeCAD units. Should I also make in SI units?
And they all pass on my system.
GSoC2020, FEM: extend examples
Re: GSoC2020, FEM: extend examples
The displacements results are as follow:bernd wrote: ↑Wed Jul 29, 2020 10:46 amDid you double check the results with calculix and the calculation from the paper in the bimetall topic.Sudhanshu wrote: ↑Wed Jul 29, 2020 9:21 am
Magnitude:
calculix: min= 0, max= 7.15
elmer: min= 0, max= 7.23
uz_max (manual): 7.05
X:
calculix: min= -0.034 , max= 0.25
elmer: min= -0.035, max= 0.25
Y:
calculix: min= -0.006, max= 0.006
elmer: min= -0.006, max= 0.006
Z:
calculix: min= -0.001, max= 7.15
elmer: min= 0, max= 7.29
All in FreeCAD standard units
So yeah, the results are all pretty close.
The temperature shown by elmer is 373K and I think I did saw 100 deg C in the manual calculation, though I am not sure if that was a given value or a result.
Anyway, the displacement results match approximately so it should be good to go.
BTW: There is a side work you could help with, if either HoWil or me are to slow in control the examples. https://forum.freecadweb.org/viewtopic. ... 10#p418922
since we had to change the mesh type of all examples to gmsh mesh to be able to remesh all examples and with the new elmer examples we started to really improve the elmer solver, this is even related to GSoC somehow. Means it could even be mentioned there as part of your work.
Sure!bernd wrote: ↑Thu Jul 30, 2020 6:25 am BTW: There is a side work you could help with, if either HoWil or me are to slow in control the examples. https://forum.freecadweb.org/viewtopic. ... 10#p418922
By the way its 30th already, so just a reminder to finish the evaluation if you haven't done it already.
I do not get this warning for the two balls example on
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.19.22184 (Git)
Build type: Unknown
Branch: femtmp
Hash: 94ca4388e499407d67aea50530c21029ac569b90
Python version: 3.7.3
Qt version: 5.11.3
Locale: German/Switzerland (de_CH)
Are you directly running the example, or setting it up and then solving it.bernd wrote: ↑Fri Jul 31, 2020 6:24 amI do not get this warning for the two balls example on
Build type: Unknown
Branch: femtmp
Qt version: 5.11.3
Cause the warning comes when you write the input file using GUI after setting up the example.
I am still getting the warning.
OS: Arch Linux (XFCE/xfce)
Version: 0.19.22184 +5 (Git)
Branch: femexamples
Hash: 3f422f27a0b2067a0cd6a6754a9fa48e5fa926a4
Python version: 3.8.3
Qt version: 5.15.0
OCC version: 7.4.0
Locale: English/India (en_IN)
Noted.
