[Possible Bug] when editing the value of a boundary condition and pressing ENTER, task disappears but still active
When editing Flow constraints in FEM Module, if pressing ENTER instead instead of clicking away from a field value input, the task disappears but remains active, thus locking FreeCAD.
How to repeat:
- Create an analysis
- Create a flow constraint
- Edit one of the numerical flow conditions and press ENTER instead of clicking away.
OS: Windows 10 (10.0)
Version: 0.19.21068 (Git)
Hash: 92fe9adebbff910c5a10d6230785a6b58935b677
Python version: 3.6.8
Qt version: 5.12.1
Locale: English/Switzerland (en_CH)
How to repeat:
Qt version: 5.12.1
Re: [Possible Bug] when editing the value of a boundary condition and pressing ENTER, task disappears but still active
I can not repeat.
Which constraint did you add, flow velocity, initial flow velocity or fluid ?
Flow velocity. I'll try to repeat a few more times to get the hang of it.
- start FreeCAD
- change to FEM
- make a new document
- add Analysis
- add a constraint flow velocity (the task panel will open automatically)
- click on the blue checkbox right beside the Velocity x, to activate the input field
- select the firs "0" and put in a "5" field will show 5.00 mm/min
- press Enter, Task panel will close
- For me the object closes the edit mode correct
- Means FreeCAD is not locked
- change to FEM
- add Analysis
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.19.21124 (Git)
Build type: Unknown
Hash: 8fcd436de1e3233d9616571679a46b4d93c3e730
Python version: 3.7.3
Qt version: 5.11.3
Locale: German/Switzerland (de_CH)
Okay I had time to reproduce the bug. Was actually super easy
1. Load the file 2. Double click the Analysis object to activate it (not necessary, just neater)
3. Double click the first ConstraintFlowVelocity (below ConstraintInitialFlowVelocity)
4. Click in the X field that reads -20 mm/s for edition
5. Backspace until no value is entered.
6. Press "20" then ENTER
Voilà!
Qt version: 5.12.1
For completeness' sake I have taken the liberty of also running the bug in the most current portable build available and it works.
Version: 0.19.21255 (Git)
Hash: dfdcd5351b686f1a452eb840b90cffff1b93c112
Qt version: 5.12.1
And the report view...for fun.
LOL I cannot copy paste the report view, because the bug actually locks me out of freecad by being stuck in Task Edit Mode
So a screenshot will have to do.
Voilà!
Qt version: 5.12.1
Qt version: 5.12.1
confirmed.
Two remarks.
- Try to make the file as simple as possible. Attached the example for this problem.
- really copy the error instead of makeing a screen. The search would find it than.
Two remarks.
File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femviewprovider/view_constraint_initialflowvelocity.py", line 82, in accept
self._applyWidgetChanges()
File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femviewprovider/view_constraint_initialflowvelocity.py", line 120, in _applyWidgetChanges
self._obj.VelocityX = float(quantity.getValueAs(unit))
<class 'ValueError'>: Unit mismatch
Hello Bernd,
Thanks for taking the time. Sure I'll try to simplify the file when I see something like this. My thinking was more to share the exact file that shows the issue.
Regarding copying the report view, I agree but CTRL-C (copying text from the report view) would not work because I was stuck in a task, it was trying to copy the ConstraintFlowVelocity object instead How did you do it?
Found another problem ...
open file and double click on the object
File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femviewprovider/view_constraint_initialflowvelocity.py", line 49, in setEdit
_TaskPanel
File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femviewprovider/view_base_femobject.py", line 102, in setEdit
task = TaskPanel(vobj.Object)
File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femviewprovider/view_constraint_initialflowvelocity.py", line 62, in __init__
self._mesh = membertools.get_single_member(analysis, "Fem::FemMeshObject")
File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtools/membertools.py", line 85, in get_single_member
objs = get_member(analysis, t)
File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtools/membertools.py", line 57, in get_member
raise ValueError("Analysis must not be None")
<class 'ValueError'>: Analysis must not be None
no problem here, but nevermind if copy does not work a screen is the only possibility.RatonLaveur wrote: ↑Tue May 26, 2020 7:13 am Regarding copying the report view, I agree but CTRL-C (copying text from the report view) would not work because I was stuck in a task, it was trying to copy the ConstraintFlowVelocity object instead How did you do it?
