See https://github.com/berndhahnebach/FreeC ... fluxsolver
Would be good if someone could give it a try or if you guys share your opinion.
HoWil wrote: ping
RatonLaveur wrote: ping
raback wrote: ping
HoWil wrote: ping
raback wrote: ping
FluxSolver takes any scalar field and computes a gradient or flux on it using the Galerkin (or DG) method. I think the "Calculate Electric Flux" just averages fluxes on nodes between the elements that share them. So there could be small difference.HoWil wrote: ↑Mon Jun 29, 2020 7:26 pm For me this is OK.
A related question @raback: is the result of the flux-solver used in combination with the electrostatic equation the same as i switch on ''Calculate Electric Flux" directly in the electrostatic equation?
"Calculate Electric Flux = False ! (default True)" is used in the "Equation = Stat Elec Solver" e.g. on page 67 in http://ftp.funet.fi/index/elmer/doc/old ... orials.pdf
