FEM constraints not on object when using placement (part design workbench)
bernd
Re: FEM constraints not on object when using placement (part design workbench)
Post by bernd » Sun Jul 26, 2020 9:57 pm
LSoltmann wrote:
Fri Jul 24, 2020 4:49 pm
I found a workaround for this issue until it can be fixed. Export the part design object to a STEP file, import the STEP file, apply the constraints to the newly imported object. Now the constraints follow the object as it's moved using placement.
ohh there is a much better one because export and import of step could cause tolerance problems because they might changes.
Use part workbench to create a simple copy of your body. The copy will be a Part on the changed placement. This works flawless with FEM.
bernd
Who is online
Users browsing this forum: T-Garnier and 3 guests
