Export Calculix results
bernd
Re: Export Calculix results
Post by bernd » Thu Aug 06, 2020 10:46 am
This is correct.
sorry my fault :oops: I should have read better the home page before posting ...
Brzo
Post by Brzo » Thu Aug 06, 2020 11:00 am
Ok, I changed FreeCAD verison to 0.19 and your code is working now, but when I choose CCX_Results and change slider value I see that the mesh is different, but the values are the same like in position zero on slider. Could you help me with this ?
bernd
Post by bernd » Thu Aug 06, 2020 11:31 am
This slider is just to visualize the results. A faktor of 1.0 shows the real deformation compared to the origin geometry. The results will be mulplied with the faktor. Means if the faktor is 1000 the defored geometry shows the deformation 1000 times mor than the real deformation.
Hope you got the point.
Brzo
Post by Brzo » Fri Aug 07, 2020 6:32 am
Ok ! I understand now ! Thank you so much for your help :).
Brzo
Post by Brzo » Fri Aug 07, 2020 9:57 am
HI Bernd, I have one more question. So when I have slider value =0 then i should see my initial geometry, and when I change it to 1 it will be geometry after adding forces ?
bernd
Post by bernd » Fri Aug 07, 2020 10:09 am
... So when I have slider value =0 then i should see my initial geometry, ...
yes
... and when I change it to 1 it will be geometry after adding forces ?
Any value different from 1 shows your deformed geometry. If the faktor is 1, you can see the calculated deformation like in real. Means if a edge is 1 m long and your deformation is 0.1 m than the shown deformation should be around 1/10 of this edge length. If you change the slider to faktor 10, the deformation ist still 0.1 m BUT it is shown 10 times bigger, thus the deformation 0.1 m is as much as the edge length of 1 m.
Try the Calculix 3D cantilever from Start WB. There the coss section length is 1.0 m and the max. deformation 0.087 m (ca 0.1 m).
bernd
Jee-Bee
Post by Jee-Bee » Mon Aug 10, 2020 5:50 am
The description from @bernd don't hold for the frequency analysis.
Brzo
Post by Brzo » Wed Aug 12, 2020 9:44 am
Ok, I understand it :) Thank you so much for your help ! :)
Who is online
Users browsing this forum: No registered users and 3 guests
