Get info from a FemMesh object
johnwang
Post by johnwang » Tue Jul 28, 2020 10:39 pm
Try to use this code to get info of a FemMesh obj. Nodes is good. Edges only have edge num, but no edge node number. Where is it stored? or it is not stored?
import Fem
femmesh = Fem.FemMesh()
femmesh.addNode(0, 0, 0, 1)
femmesh.addNode(1, 0, 0, 2)
femmesh.addNode(0.5, 1, 0, 3)
femmesh.addEdge([1,2], 1)
femmesh.addEdge([2,3], 2)
femmesh.addEdge([3,1], 3)
Fem.show(femmesh)
print (femmesh.Nodes)
print (femmesh.Edges)
Result
{1: Vector (0.0, 0.0, 0.0), 2: Vector (1.0, 0.0, 0.0), 3: Vector (0.5, 1.0, 0.0)}
(1, 2, 3)
Regards,
John
Pre/Post processing CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2)
https://github.com/ceanwang
Re: Get info from a FemMesh object
Post by wmayer » Wed Jul 29, 2020 6:04 am
femmesh.getElementNodes(1) # (1, 2)
femmesh.getElementNodes(2) # (2, 3)
femmesh.getElementNodes(3) # (3, 1)
johnwang
Post by johnwang » Wed Jul 29, 2020 8:06 am
Interesting. Edge and Face all called element in FemMesh.
Thank you very much.
Post by bernd » Wed Jul 29, 2020 10:36 am
and Volumes too.
johnwang
Post by johnwang » Wed Jul 29, 2020 12:01 pm
and Volumes too.
Is there Element Type? I use the node length of a FemMesh element to decide how to add a Face. If 2d & 3d mixed, maybe there is problem.
import Fem
femmeshOrg = Fem.FemMesh()
femmeshOrg.addNode(0, 0, 0, 1)
femmeshOrg.addNode(1, 0, 0, 2)
femmeshOrg.addNode(0.5, 1, 0, 3)
femmeshOrg.addFace([1,2,3])
#Fem.show(femmeshOrg)
nodes=femmeshOrg.Nodes
faces=femmeshOrg.Faces
femmeshNew = Fem.FemMesh()
for id in range(len(nodes)):
	femmeshNew.addNode(nodes[id+1].x,nodes[id+1].y,nodes[id+1].z,id+1)
for id in range(len(faces)):
	nd=femmeshOrg.getElementNodes(id+1)
	#femmesh.addFace([nd])
	nlen=len(nd)
	if nlen==3:
		femmeshNew.addFace([nd[0],nd[1],nd[2]])
	elif nlen==4:
		femmeshNew.addFace([nd[0],nd[1],nd[2],nd[3]])
Fem.show(femmeshNew)
Post by bernd » Thu Jul 30, 2020 7:22 am
ATM no there is no problem. All edge elemnts have different node lengths, all face elements have different node lengths and all volume elements have different node lengths.
But mainly you are right. If there where some elements with same node length we would be in trouble.
https://github.com/berndhahnebach/FreeC ... p.cpp#L277
https://github.com/berndhahnebach/FreeC ... p.cpp#L367
https://github.com/berndhahnebach/FreeC ... p.cpp#L500
FEM_Mesh
Post by wmayer » Thu Jul 30, 2020 12:09 pm
To figure out of what type an element is use the method getElementType(Id). It returns a string like, "Node", "Edge", "Face", "Volume", "0DElement" or "Ball".
Unless it's intended your code has some flaws because you won't copy over all nodes. The Nodes attribute already returns a dict with Id+Vector and can be easily copied with:
for i in femmesh.Nodes.items():
    femmeshNew.addNode(*i[1], i[0])
Then when adding the faces there is no need to explicitly check for the number of nodes. Just use the * operator and you are done:
for id in faces:
    nd = femmesh.getElementNodes(id)
    femmeshNew.addFace([*nd])
Full example:
import Fem
femmesh.addNode(2, 0, 0, 2)
femmesh.addNode(2, 2, 0, 3)
femmesh.addNode(0, 2, 0, 4)
femmesh.addNode(1, 1, 1, 5)
femmesh.addEdge([3,4], 3)
femmesh.addEdge([4,1], 4)
femmesh.addEdge([1,5], 5)
femmesh.addEdge([2,5], 6)
femmesh.addEdge([3,5], 7)
femmesh.addEdge([4,5], 8)
femmesh.addFace([1,4,3,2], 9)
femmesh.addFace([1,2,5], 10)
femmesh.addFace([2,3,5], 11)
femmesh.addFace([3,4,5], 12)
femmesh.addFace([4,1,5], 13)
Fem.show(femmesh)
nodes = femmesh.Nodes
faces = femmesh.Faces
for id in faces:
johnwang
Post by johnwang » Thu Jul 30, 2020 12:58 pm
for id in faces:
I thought of this, but haven't figured it out. So I comment this line out.
Yeah, I need that * operator.
Thank you very much again.
Who is online
