FEM gmsh Mesh cannot makes volume
qwqwhs
Post by qwqwhs » Mon Aug 17, 2020 7:59 am
Hello, I designed a tiny heat sink and I'd like to test it with FEM.
The problem is the FreeCad gmsh cannot make the volume mesh of my model.
Isome forum said, "set Max size of element appropriately" but I cannot test it because when I set the max size as 0.5mm then it stops.
Could you help me?
The file size is big so an attached the drive link
https://drive.google.com/file/d/1xhIE19 ... sp=sharing
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: Korean/SouthKorea (ko_KR)
Re: FEM gmsh Mesh cannot makes volume
Post by chrisb » Mon Aug 17, 2020 9:09 am
Moved to FEM forum.
Jee-Bee
Post by Jee-Bee » Mon Aug 17, 2020 11:03 am
When i check the model in part (part >> check geometry: https://wiki.freecadweb.org/Part_CheckGeometry)
HeatSink.refine:
  VERTEX    : 618
  EDGE      : 914
  WIRE      : 317
  FACE      : 301
  SHELL     : 1
  SOLID     : 1
  COMPSOLID : 0
  COMPOUND  : 1
  SHAPE     : 2153
it looks like it is a solid.
When i set the bop check on i got a bunch of errors. could be possible that the reason of your problem.
domad
Post by domad » Mon Aug 17, 2020 11:34 am
Hello!
Tip: when performing Boolean operations it is preferable that the contact surfaces are not coplanar but interpenetrating by a few tenths of mm.
This is the error report from FEM Mesh Gmsh:
“Error : Invalid boundary mesh (overlapping facets) on surface 251 surface 253 Error : No elements in volume 1 Warning : Surface mesh: worst distortion = -2594.44 (avg = -0.393704, 99 elements with jac.”
A further investigation was not possible because your file is not complete with all the parametric construction phases.
However I think this can be very useful to you: https://forum.freecadweb.org/viewtopic.php?t=34912
Hi Good job!
Who is online
Users browsing this forum: No registered users and 1 guest
