I am trying to assess the likely distortion of a structure. I have successfully completed the process with a simple tube. However, keeping getting an error when I attempt to simulate a more complex structure.
I suspect my problem may relate to mesh cell sizing, I have tried varying various meshing parameters without any luck. However, I am not sure that I fully understand the intended effect of the parameters I'm varying!
Any help would be appreciated.
Thanks.
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Newbie: Help with FEM. CalculiX finished with error 3221225477
- THree_poles_with_analysis_1.FCStd
- FreeCad file
- (115.47 KiB) Downloaded 26 times
- Error message
- CalculiX_error.jpg (14.32 KiB) Viewed 922 times
- Image of structure being analysed
- Image_1a.jpg (501.73 KiB) Viewed 922 times
Re: Newbie: Help with FEM. CalculiX finished with error 3221225477
Try v0.19 per https://forum.freecadweb.org/viewtopic.php?f=18&t=12212
I don't have checked in detail...
What i can see so fast is this You have a lot of intersections. Don't know if it is just graphical... (i prefer to use part as less as possible) at least i think you have to fix that all flat... beams / ... whatever it is called.
Thank you for your replies. Sorry for taking so long to respond.
I have installed the latest version of FreeCAD from: https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
Simulating the original structure caused FreeCAD to crash.
I have redrawn the structure. During the simulation it finishes with an error as shown.
With regards "rough finishes" to the structure. I have to admit I am much more experienced using SolidWorks as a CAD tool. I am sure that I am drawing the FreeCAD part incorrectly - sorry about that. However, what I have done is tried to ensure that all of the elements of the part intersect and then Fuse the elements. On the assumption that FreeCAD would take that as a solid part.
Any thoughts or guidance would be much appreciated.
OS: Windows 10 (10.0)
Version: 0.19.22522 (Git)
Hash: d8e476ef428017900dfe0f9359ba448503c216f9
Python version: 3.8.5
Qt version: 5.12.6
OCC version: 7.4.0
Qt version: 5.12.6
OCC version: 7.4.0
- New_Three_pole_1a.FCStd
- (37.48 KiB) Downloaded 16 times
- Error_2_large.JPG (667.5 KiB) Viewed 743 times
- CalculiX_error_2.jpg (294.26 KiB) Viewed 743 times
