I did not find help in the BIM workbench forum
https://forum.freecadweb.org/viewtopic.php?f=23&t=53503
I am trying to resize all structural members creating in the BIM WB, analyse using the FEM WB then return to BIM WB and resize the columns correctly, per level.
PD: Inside the link is a sample of array with structural members.
Which is the workflow between BIM and FEM workbench?
Re: Which is the workflow between BIM and FEM workbench?
You mean interacting between BIM workbench and FEM workbench like a ping pong between them for topological optimization? This is not implemented ATM.
I did not found documentation or tutorials or videos to use "Reinforced material". so I am not sure if I should add rebar and concrete and create a reference, I tried but just leave errors.
what should do here?
how should I use "Reinforced Material"?
