whenever i have some problems when e.g. using tangential constraints in combination with parameters from a spreadsheet. Mostly there a more than one solutions to a set of constraints. A tangent to a circle can fit 2 points on the circle.
Helpful would be a constraint "without value" e.g. define a horizontal or vertical constraint with "has to be >=0" or "has to be<=0" to make the soltion unique. Is something like this possible? Or "in development"? Is the solver able to use something like this? Or is there another solution?
See the attached example:
This should be a clamp that connects to tubes. The clamp "opening" is set to a specific width - smaller than the tube diameter - constraint by construction lines that are tangential to the tips of the clamp (i have marked it with arrows). But there are 2 solutions. One where the inner circle of the clamp goes over 180° and one where it has less than 180°. If i change parameters something like this can happen:
Obviously this is a correct solution for the constraints. But it does not work for the intended purpose. If i could define a constraint that sets the distance between the center of the circle and the tangent points to be ">0" everything would be fine.
But i did not find a function like this. Am i missing something? Or is there another way to ensure the "correct" solution? BTW: The message from the solver that the sketch is fully constraint is WRONG! It is NOT as there are (at least) 2 possible solutions.
Ciao, Udo
Sketcher constraints have non-unique solution
Re: Sketcher constraints have non-unique solution
Currently it is not possible to enter inequalities as constraints. The problem has been discussed in the forum, e.g. here: https://forum.freecadweb.org/viewtopic. ... t=infinite
