[Merged] PR #2389 - Thickness tools is missing intersection-toggle option
rynn
Post by rynn » Wed Jul 24, 2019 2:15 pm
The thickness-tool from part has a intersection-toggle-option (not the join type) that, in same cases, is necessary to p.e. apply an inward thickness (Part: negativ thickness, Part-design: Reversed == true").
This option is missing from the part-design thickness-tool.
OS: Ubuntu 16.04.6 LTS (GNOME/gnome)
Version: 0.19.17469 (Git)
Hash: 96b74022e3681c9e5bde88ea72ae9c412e25ed20
Python version: 2.7.12
Thickness-example.FCStd
(34.98 KiB) Downloaded 27 times
openBrain
Re: Thickness tools is missing intersection-toogle
Post by openBrain » Wed Jul 24, 2019 3:00 pm
What are proposing then ? Some code or PR ?
If the purpose of your post is to get help or confirm it's a bug & deserves a ticket, it should be located in the Help subforum. ;)
rynn
Post by rynn » Wed Jul 24, 2019 3:27 pm
I don’t think it’s a bug, more of a missing feature.
In my case this is easy to fix: simply set the intersection parameter in the Part::TopoShape::makeThickSolid call to true.
But I’m not sure what this means for other uses, as I do not understand the parameters at all.
patch.txt
Patch: set intersect == true
(733 Bytes) Downloaded 30 times
rynn
Post by rynn » Thu Jul 25, 2019 11:52 am
I added a Intersection-option to toggle the intersection flag.
Patch appended.
Thickness.patch.txt
(6.59 KiB) Downloaded 32 times
openBrain
Post by openBrain » Thu Jul 25, 2019 12:20 pm
Great. Would it be possible that you submit a PR in GitHub rather than a unified diff here ?
Note that before doing so, you have to :
  • Basically ensure that your code is working and doesn't introduce regressions
  • Rebase against the latest master
  • Locally run the test set
rynn
Post by rynn » Wed Jul 31, 2019 11:19 am
Added a PR: https://github.com/FreeCAD/FreeCAD/pull/2389
TestPartDesignApp and TestPartDesignGui are passing here.
openBrain
Post by openBrain » Wed Jul 31, 2019 12:15 pm
:+1:
freecad-heini-1
Post by freecad-heini-1 » Wed Jul 31, 2019 4:18 pm
Unfortunately I don't know how to add improvements to Freecad. My question about this improvement. Until when will it be included in the daily Builds versions? What about the Thickness Tool of the Part-Workbench? Will this be improved at the same time, or is this a separate process? Is there a benchmark test or something similar to test if the tool can hollow out parts that didn't work before? I'm looking forward to answers.
Many greetings
Wilfried
Translated with www.DeepL.com/Translator
rynn
Post by rynn » Wed Jul 31, 2019 7:23 pm
This feature already is in the Part-workbench Thickness tool. It was missing in PartDesign only.
There is another toggle in the Part Thickness tool (Self-intersection), that I don’t understand.
rynn
Post by rynn » Fri Aug 23, 2019 6:34 am
Is there some additional procedure one has to do, to get a pull-request pulled?
Who is online
Users browsing this forum: No registered users and 1 guest
