Additive Sweep with Subtractive cylinders
Aurawin
Post by Aurawin » Mon Nov 18, 2019 4:13 pm
There is a problem with the subtractive nature of cylinders when the cylinder's center is at the start of a sweep.
Screenshot from 2019-11-18 09-49-29.png (47.52 KiB) Viewed 306 times
Screenshot from 2019-11-18 09-55-16.png (13.09 KiB) Viewed 306 times
Screenshot from 2019-11-18 09-57-15.png (23.84 KiB) Viewed 306 times
If I move the last cylinder's z off the plane - even by 1nm the render if perfect. When the item is moved from the y-axis it needs to be positioned to where the entire item is no longer intersecting with the start of the sweep - which I find strange.
Offsetting the position of the subtractive does workaround the issue but it should not require me to introduce fake tolerances to get the part to render properly.
Topper.FCStd
(233.22 KiB) Downloaded 15 times
openBrain
Re: Additive Sweep with Subtractive cylinders
Post by openBrain » Mon Nov 18, 2019 5:41 pm
Yep. seamlines create some problems. Yours is one of them. :)
There isn't much doable at FreeCAD code level because this is induced by the third party geometric kernel (openCascade). ATM, using workarounds such as slight moves is required.
Who is online
Users browsing this forum: No registered users and 2 guests
