Bug: PartDesign: Loose of placement information at a sub-object shape binder
cappu
Post by cappu » Wed Dec 18, 2019 10:51 am
The placement-information is lost at sub-object shape binder in some cases:
OS: Ubuntu 18.04.3 LTS (XFCE/xubuntu)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
See also LibreOffice document with some screenshots
1) Create New file.
2) Save as : SpiralSaveTest
3) Change to: Part Design
4) Create new Part, Create New Body, Create new scetch xy-plane
5) Pad to 10mm
6) Change to Part-Workbench
7) Create Spiral: Grow:8mm. Rotation:2, radius 2mm
8) Change to Part-Design Workbench,
9) create 2 Sub-Object Shape-Binder on the Spiral
10) Change parameter of second Binder (Name Binder 001) to: Placement,Angle 180° and z=1
11) Create 2 similar sketch in body in xz-plane
12) Create two sweeps (for each scetch with the binder starting at the sketch)
13) Save file
14) Close FreeCad
15) Open FreeCad
16) Load SpiralSaveTest
17) Change to Part-Design-WB
18) Create new sketch in xz-plane
19) !!! suprisingly the binder001 looses his Placement-information (180° Rotation around z)
SpiralSaveTest.pdf
(1000.51 KiB) Downloaded 10 times
SpiralSaveTest.FCStd
(409.7 KiB) Downloaded 7 times
DeepSOIC
Re: Bug: PartDesign: Loose of placement information at a sub-object shape binder
Post by DeepSOIC » Wed Dec 18, 2019 11:05 am
Shapebinders are not movable. You may be able to change its placement only because you right-click->show all in property editor. That shows hidden properties. Properties are hidden when they are not designed to be messed with.
cappu
Post by cappu » Wed Dec 18, 2019 11:21 am
In new version 0.19 there are new: Sub-Pbject-Shape binder (new Green area) / icon.
At these new objects plaCement can be adjusted with placement-attributes.
(see attached pickture, the green area)
It also works fine until saved, opened and changed somewhere. Please follow my failure-instruction to find out in new Version: 0.19.
DeepSOIC
Post by DeepSOIC » Wed Dec 18, 2019 1:18 pm
the green area
ok, I'm not really familiar with this tool, so let's ask the creator:
realthunder wrote:Ding!
Post by chrisb » Wed Dec 18, 2019 3:26 pm
The ShapeBinder property TraceSupport controls if the ShapeBinder follows the Placement of its source or not.
cappu
Post by cappu » Wed Dec 18, 2019 3:37 pm
Hello chrisb, there is not property TraceSupport available:
It is a new feature in FreeCad 0.19-
Please find the attributes of the Sub-Object Shape Binder
cappu
Post by cappu » Wed Dec 18, 2019 3:43 pm
Hello chrisb,
there is a similar attribute: "Bind Mode":Synchronized.
My expectation was, that at the Sub-Object Shape-Binder the attribute Placement makes sense.
Even, if you look on previous screenshot, there is the attribute Placement with angle=180°.
This changes to 0 if a new sketch is created. Did you open the attached model and tried to create a sketch below "Body"? Maybe this happens only on my system?
cappu
Post by cappu » Wed Dec 18, 2019 3:44 pm
I am not sure about meaning of "Ding!" from realthunder.
For me it looks like a bug in development version which can/should be solved before release.
When realthunder writes "Ding" does it mean he was able to reproduce the failure and is he able to solve or arrange to solve it?
DeepSOIC
Post by DeepSOIC » Wed Dec 18, 2019 3:48 pm
It is a false quote that I artificially crafted to trick the forum into thinking I replied to some realthunder's post. Realthunder will get a notification, and notice the thread.
It's a common tactic here, our forum doesn't have a mention system.
Realthunder is the creator of the feature, for sure he's the one who knows what it's supposed to do.
Post by chrisb » Wed Dec 18, 2019 5:02 pm
The comment applies to the blue ShapeBinder only. I think realthunder developed his orange shapebinders before the TraceSupport property was available.
Who is online
Users browsing this forum: No registered users and 2 guests
