Possible Bug. Sketcher issue when applying tangent to two arcs
Karl1459
Post by Karl1459 » Sat Dec 21, 2019 8:14 pm
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
New Drawing.
In Part design create new body, then new sketch.
In sketcher,
Making two arcs with one point on each arc coincident to each other.
Then attempting to apply the tangent constraint.
Coincident constraint is BROKEN. Tangent is not applied.
Workaround.
Apply tangent constraint First.
Make arcs points coincident Second.
SketcherBug1.FCStd
(4.95 KiB) Downloaded 5 times
SketcherBug2.FCStd
(4.84 KiB) Downloaded 6 times
SketcherBug3.FCStd
(4.97 KiB) Downloaded 4 times
DeepSOIC
Re: Possible Bug. Sketcher issue when applying tangent to two arcs
Post by DeepSOIC » Sat Dec 21, 2019 8:31 pm
This is incorrect (well, it may not be from user's standpoint, but let's say it's a problem with how the solver works, fundamentally). You should select endpoints of the two arcs (before they are coincident), and apply tangent. This will make a tangent connection, with well-defined constraint math.
Sketcher attempted to fix your mistake, but it's been reported already that it doesn't work when auto-remove-redundants is enabled. That is indeed a bug.
Karl1459
Re: Possible Bug. Sketcher issue when applying tangent to two arcs PREVIOUSLY REORTED
Post by Karl1459 » Sun Dec 22, 2019 8:16 am
Thanks for the quick evaluation and reply. Your time is appreciated!
I attempted the exercise with the "auto remove redundancies" box unchecked, and (from my users perspective) received the expected result. So that IS the issue.
Perhaps in the future, for those of us in the great unwashed masses not familiar with constraint math, documentation of the hierarchy of constraint actions would be helpful... maybe version 5.x or so...
Post by chrisb » Sun Dec 22, 2019 8:51 am
There is quite some documentation on sketching. You may have a look at https://owncloud.gwdg.de/index.php/s/HS ... I/download
Who is online
Users browsing this forum: No registered users and 1 guest
