Ticket #4233 - Access violation and file corruption after undo duplicate sketch
Waldschrat
Post by Waldschrat » Tue Dec 24, 2019 6:02 am
This is the discussion topic for issue #4233
Duplicating and then undoing causes, I guess, internal memory corruption, leading to access violations on subsequent operations and unusable corrupted file on save.
Steps to reproduce:
- Open file attached to the bug report. (Or just create a cube by padding a sketch.)
- Go to Part Design workbench.
- Select top face of cube.
- Create new sketch attached to selected face.
- Draw something, maybe a circle around the coordinate center.
- Close sketch.
- Select sketch in tree view.
- Click Edit --> Duplicate selected object.
- Click Yes.
- Click Edit --> Undo
- Click No.
- Observe "Exception - Access violation"
- Click OK twice.
- Save file.
- Close and reopen FreeCAD.
- Open recently saved file.
- Observe a totally unusable file.
FreeCAD infos:
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Reason: Added ticket number to thread title
Re: Access violation and file corruption after undo duplicate sketch
Post by chrisb » Tue Dec 24, 2019 9:06 am
Please retry with current 0.19. Follow next time the bug report guidelines and discuss the issue before creating a bug report.
Waldschrat
Post by Waldschrat » Tue Dec 24, 2019 11:26 am
I tried to run 0.19_pre3_19036: https://github.com/FreeCAD/FreeCAD/rele ... nVS2015.7z
Downloading, unpacking and running as per instructions here: https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
But it fails during startup complaining about missing VCRUNTIME140_1.dll
I guess I have to install something before (some visual studio redistributable, I guess) or use a different file maybe. Any tips?
Site Admin
Post by wmayer » Tue Dec 24, 2019 11:46 am
I can confirm the crash with v0.18 but not with v0.19. See also the ticket for further details.
The document is already corrupted after the undo and when using the Dependency graph utility it crashes when it tries to create the graph. So, very likely it's caused by a dangling pointer.
If you look at the undo history before undoing the last action you will realize that the duplication created two actions:
  1. Duplicate
  2. Duplicate a PartDesign object
When searching for this term in the source code you will find this function: https://github.com/FreeCAD/FreeCAD/blob ... y.cpp#L639
So, this function is a special re-implementation of the duplication function of the core system but does some extra PartDesign handling.
If you look at its implementation then it does:
  • Opens a transaction
  • Invokes the duplication function of the core system which also opens and commits a transaction
  • Modifies the the document
This however is a convoluted logic and creates a big mess because when opening a transaction while another one is opened the latter will be closed automatically. So, the consequence is that the invocation of the core duplication function closes the Duplicate a PartDesign object transaction and its own transaction. When the duplication function returns to its calling instance there is no pending transaction any more and further changes are not logged by a transaction.
This means parts of the operation are logged by a transaction and other parts aren't.
A workaround for now is to switch to any other workbench to make sure only the core duplication function is used. Then the document won't have inconsistencies and undo doesn't break its internal structure.
Site Admin
Post by wmayer » Tue Dec 24, 2019 11:47 am
You need the redistributable for VS2015 and x64.
Site Admin
Post by wmayer » Tue Dec 24, 2019 11:54 am
Fixed with: https://github.com/FreeCAD/FreeCAD/comm ... 79dfa630cb
Note: To get the same state as before duplicating objects you must press undo twice.
Waldschrat
Post by Waldschrat » Tue Dec 24, 2019 12:28 pm
Ah, nice, thanks, mightily quick work, that.
Classic, I guess. Call with unexpected side effect.
I think I'll stop fighting VS and test it when the next release comes out.
Who is online
Users browsing this forum: No registered users and 1 guest
