"16Standard_Failure Index" spamming report window.
freman
Post by freman » Mon Jan 06, 2020 8:18 am
For several months now I have been seeing the report window spammed with red letter error messages like the following.
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Edge3
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Edge4
I am not aware of this causing further problems, so maybe it should not be showing up in the report window at all.
It seems that the cause of this needs to be determined and if it is an 'expected' error condition that it is suitably swallowed or fixed so that it does not constantly produce garbage in the report window. This is a problem since it desensitises the user to output which occurs there, which should be significant.
I recently failed to notice some significant output on another issue and realised that I had subconsciously started to tune out what appears in report window since it is often irrelevant junk. It also means I need to constantly clear the report window so that new error messages catch the eye instead of blurring into the background of existing bright red spam.
On the other hand, if this does represent a real problem, it probably needs fixing to prevent it flooding the report window.
The attached file produced the above output when I selected the three circles and added a diameter constraint.
thx.
OS: Fedora 31 (Thirty One) (LXDE/LXDE)
Version: 0.19.19145 (Git)
Hash: c43315728cc643c6a382af0bba5b596407bbaf26
Python version: 3.7.5
Qt version: 5.12.5
working further on this drawing :
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Edge16
<Part> PartFeature.cpp(191): 16Standard_Failure Unsupported sub-shape type: Unnamed#Sketch.Constraint27
<Part> PartFeature.cpp(191): 16Standard_Failure Unsupported sub-shape type: Unnamed#Sketch.Constraint30
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Edge17
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Vertex27
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Vertex26
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Edge18
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Vertex28
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Vertex29
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Vertex30
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Edge19
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Vertex31
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Vertex38
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Vertex12
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Vertex11
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Edge8
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Edge15
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: Unnamed#Sketch.Edge14
... like I said: spamming the report window.
std-feature-index.FCStd
(4.03 KiB) Downloaded 9 times
Who is online
Users browsing this forum: No registered users and 2 guests
