broken fillet
freman
broken fillet
Post by freman » Mon Jan 06, 2020 9:46 am
in adding a fillet to this model I get a missing segment in the fillet.
Having applied 10mm fillet to one side I turn the object and select the three edges at the back of the handle. The initial default 1mm fillet is fine and works up to 8mm. In stepping from 8 to 9mm it breaks leaving a gap in the surface as shown.
The central hole takes 10mm on each side without problems.
Further fiddling reveals even 8.01mm triggers the bug. It seems that this is point when the fillet touches lower edge. This was not an issue on the other side as show in upper image.
OS: Fedora 31 (Thirty One) (LXDE/LXDE)
Version: 0.19.19145 (Git)
Hash: c43315728cc643c6a382af0bba5b596407bbaf26
Python version: 3.7.5
Qt version: 5.12.5
saw.FCStd
(47.44 KiB) Downloaded 14 times
Re: broken fillet
Post by chrisb » Mon Jan 06, 2020 7:03 pm
I can very well understand and explain why it fails. At a radius of 8 mm the fillet just touches the line at the bottom. As fillets cannot consume the whole adjacent face it fails as soon as you go further down.
I have absolutely no idea why it works on the other side.
freman
Re: broken fillet
Post by freman » Mon Jan 06, 2020 7:25 pm
Thanks. So you are saying that the bug is the side which "works", not the one missing a face ?
At a wild guess from past experience, I'd say it has something to do with what is "in front" of what when the the two lines meet in a point.
It is clear which is the most useful result, even if someone says it is not technically a fillet where it does not meet the other face tangentially.
Re: broken fillet
Post by chrisb » Mon Jan 06, 2020 9:05 pm
Sad to say, but yes, that's how I see it.
freman
Re: broken fillet
Post by freman » Mon Jan 06, 2020 9:56 pm
I don't see it as sad. Technically you are probably correct , as I suggested.
However, there are two choices, one of which is of no use, the other is useful. The real bug is the inconsistency.
If someone is inclined to fix this issue, they need to work out which way to go.
1. Leave missing surfaces if the fillet does not meet tangentially along its full length.
2. Produce complete, machinable surfaces which are technically not called "fillets" in such cases.
I guess that looks a bit like German rigour vs French pragmatism. ;)
openBrain
Re: broken fillet
Post by openBrain » Mon Jan 06, 2020 10:19 pm
chrisb gave the German rigor, so let's go for the French pragmatism. :)
Actually there is no real inconsistency in this (even if I agree it looks like for normal user).
Very probably, because of rounding errors introduced by the use of floating point computation in FreeCAD core, there are still some picometers of valid material on the working side, and oppositely there are missing some picometers of material on the failing side. :)
Re: broken fillet
Post by chrisb » Mon Jan 06, 2020 10:29 pm
Here we are, still not really knowing why it works:
Snip macro screenshot-fff96c.png (13.16 KiB) Viewed 328 times
saw_cb.FCStd
(30.25 KiB) Downloaded 8 times
freecad-heini-1
Re: broken fillet
Post by freecad-heini-1 » Tue Jan 07, 2020 6:28 am
My trick is to increase the "material" for the fillet, create the fillet, and later cut the material off, please watch my video:
https://peertube.mastodon.host/videos/w ... a375b14fa6
Re: broken fillet
Post by chrisb » Tue Jan 07, 2020 8:32 am
Very good idea - and independent of some unknown coincidences.
freman
Re: broken fillet
Post by freman » Tue Jan 07, 2020 9:05 am
thanks for a solution Chris. There definitely is something odd in what produces a fillet and what does not.
@heini, thanks for the ingenious work around. It's a little annoying when tricking FC to do the job takes longer than doing it with a sheet of sand-paper. :(
I'll open a bug about this later, when I have more time.
Here's another oddity. I wanted to hide the fillet and look at the pad to identify which edges Chris had used to get this to work. In fact what I get is half and half. I'm wondering whether the fact that my pad was "symmetrical to plane" is a factor in the anomalous behaviour.
Ah no, I've just seen that Chris used a mirror to get it to work.
Who is online
Users browsing this forum: No registered users and 1 guest
