broken fillet
Re: broken fillet
No need to open a bug, it is known behaviour, to OCC as well; and its nothing FreeCAD developers can do about it.
freman
Re: broken fillet
Post by freman »
Thanks, that saves some time.
What is the situation with OCC developement? Did they end developing the code and release it as OSS because they decided to not continue with it, or is it an ongoing project where such bugs can be reported?
The 3D surface tool made quite a nice job of left-hand half of the profile but it's very slow for a decent finish ( 1mm x 0.5mm ) . It takes over 30s to make a path and about twice that to write it out as GCODE. I'm guessing that is probably a result of most of it being python script and inefficiencies of constantly swapping data formats between the various libraries. A quick look at the code shows even the most trivial low levels calculations seems to be constantly calling helper classes to convert vectors and points back and forth.
Re: broken fillet
freman wrote: Wed Jan 08, 2020 11:22 am What is the situation with OCC developement?
You can see from the version numbers used, that OCC is still under development. However, it seems that they know that fillets need some love, they have noone working on it.
freman
Re: broken fillet
Post by freman »
Looks like they may be on to this one at least :)
https://tracker.dev.opencascade.org/view.php?id=28354
