Ticket #4399 - sketcher behavior generating a lock constraint in reference mode
bluebaer
Post by bluebaer » Fri Jul 03, 2020 8:24 pm
I stumbled across a odd behavoir of the sketcher when with "lock constraint" when toggling from/to reference mode.
Following setup:
- make 1st sketch on xy with fully constraint sqaure
- make 2nd sketch on xy and "external reference" on line on sketch 1.
- toggle to reference constraint mode
- lock on end point of sktech
Expected behavior: two blue reference constraint
Precieved behavior: two red constraints
When playing further things get more mixed up...
Please see demo file (delete sketch001 to reproduce).
Test_File_sktech_bug.FCStd
(10.76 KiB) Downloaded 25 times
And Gif.
Topic can be reproduced in:
OS: Windows 10 (10.0)
Version: 0.19.21775 (Git)
Hash: 1f741aa511e898849e46ed14515fce416fe32acb
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
and assembly-3 release from realthunder 0.11 2020.06.18
Can someone to reproduce / any advice?
Reason: Added ticket number to thread title
Re: sketcher behavior generating a lock constraint in reference mode
Post by chrisb » Fri Jul 03, 2020 8:44 pm
Confirmed.
Reproducing and showing desired behaviour can be slightly simplified:
Reproduce:
- in second sketch create a reference to external geometry.
- select an endpoint of the reference geometry
- add lock constraint
-> normal (red) constraints are added and correctly a redundancy error is detected.
To show expected behaviour:
- add a vertical distance constraint -> is added as (blue) driven dimension
- add a horizontal distance constraint -> is added as (blue) driven dimension
Would you please create a ticket?
OS: macOS High Sierra (10.13)
Version: 0.19.21671 (Git)
Hash: f05253f882b336f56aae32593faa5676fd5aafdd
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
bluebaer
Post by bluebaer » Sun Jul 05, 2020 11:50 am
Post by chrisb » Sun Jul 05, 2020 11:28 pm
Thanks! For your next ticket: You can use the "bug" tag and simply enter the number. That creates a link to the ticket.
Bei3lay
Re: Ticket #4399 - sketcher behavior generating a lock constraint in reference mode
Post by Bei3lay » Sat Oct 24, 2020 3:37 pm
Solved in PR 3995.
Who is online
Users browsing this forum: No registered users and 1 guest
