The Loft dialog does not take into account the options of the loft.
An example:
This loft has the option "ruled" set but the dialog does not reflect this.
Looking at the code I see that the dialog is simply not properly initialized.
This PR fixes this bug: https://github.com/FreeCAD/FreeCAD/pull/3871
[fixed] UI bug with Loft dialog
- Pauvres_honteux
Re: UI bug with Loft dialog
Hi uwestoehr, do I interpret your gif correct if I say "ruled" = smoothing the resulting surface?
No. See: https://wiki.freecadweb.org/PartDesign_ ... ft#OptionsPauvres_honteux wrote: ↑Tue Sep 15, 2020 1:03 pm Hi uwestoehr, do I interpret your gif correct if I say "ruled" = smoothing the resulting surface?
