missing feature to change loft section order
uwestoehr
Re: missing feature to change loft section order
Post by uwestoehr » Thu Sep 17, 2020 11:45 am
Hmm, after you merged my https://github.com/FreeCAD/FreeCAD/pull/3876 and your subsequent fixes, the intended feature does no longer work:
I have a sweep with several sections and I cannot select one section and press DEL. I can use the context menu to delete, but not the DEL key.
I cannot see from the code why this happens. I worked yesterday on my development PC.
Post by chrisb » Thu Sep 17, 2020 11:53 am
uwestoehr wrote:
Thu Sep 17, 2020 11:38 am
However, in your example, the resulting part's outer wall is black (the color I get when e.g. unions fail):
That means only that the inside is out, which happens because the shape starts inside in the other direction.
Site Admin
Post by wmayer » Thu Sep 17, 2020 2:33 pm
What about my PR for lofts:
https://github.com/FreeCAD/FreeCAD/pull/3871
Do I have to change there anything to be merged?
I can only merge one PR after the other...
I haven't touched anything in this regard. Are you sure it has worked before? When I use the Del key in the sections panel I get this Qt warning:
QAction::eventFilter: Ambiguous shortcut overload: Entf
Since you have added the Del shortcut to all three sub-panels and they are all active at the same time Qt is not able to handle this. A workaround is to hide the other two sub-panels with the arrow buttons.
uwestoehr
Post by uwestoehr » Thu Sep 17, 2020 2:46 pm
You misunderstood me. I know your spare time is limited. I was just seeing merge conflicts because of your recent changes. So I wondered if I have to do something according to your recent changes. So no time pressure but need to learn. (You know I will have to extend the pad feature soon and see that I need to learn more in the UI field.)
Argh, I am so untalented. To keep the overview I collapsed the other 2 lists and only worked on one. And yes, with my test setup:
it works.
Of course I cannot bind the same key to 3 different lists. Stupid me.
Site Admin
Post by wmayer » Thu Sep 17, 2020 2:56 pm
Ah, no action required. I will merge it soon and fix the conflicts myself.
Don't worry it's not about talent, it's about experience and to learn the pitfalls of the used libraries. So, far you did a very good job with all your PRs.
uwestoehr
Post by uwestoehr » Thu Sep 17, 2020 11:06 pm
...So I wondered if I have to do something according to your recent changes...
There was one according to your yesterday's commits. Here's the PR: https://github.com/FreeCAD/FreeCAD/pull/3877
Who is online
Users browsing this forum: No registered users and 1 guest
