[Duplicate] Possible bug: Cross-hair misaligned in Sketcher
davidosterberg
Post by davidosterberg » Fri Sep 18, 2020 6:04 pm
I am experiencing a bug in the latest windows build of 0.19 (installed today).
The cross hair in sketcher is not actually aligned with the coordinates.
For example, when trying to sketch with auto constraints, I have to aim to the side as can be seen in attached image.
crosshair misaligned
OS: Windows 10 (10.0)
Version: 0.19.22411 (Git)
Hash: d4519d5aec15bc08f029da5ed15410a494b57b2c
Python version: 3.8.5
Qt version: 5.12.6
OCC version: 7.4.0
Locale: English/Denmark (en_DK)
Reason: Duplicate
Re: Possible bug: Cross-hair misaligned in Sketcher
Post by chrisb » Fri Sep 18, 2020 6:27 pm
Hi and welcome to the forum!
There is a certain radius around a point where you can catch the point. You can play with Preferences->Display->Colors->PickRadius. (And yes, we know that the place of this setting is a bit special).
davidosterberg
Post by davidosterberg » Sat Sep 19, 2020 8:50 am
Thanks Chrisb. My concern and the reason that I consider it a bug is that if I actually aim correctly the point will not catch.
Edit:
2020-09-19 10_50_42-FreeCAD 0.19.png (2.9 KiB) Viewed 517 times
Post by chrisb » Sat Sep 19, 2020 8:58 am
I cannot confirm on MacOS. I have set pick radius to 7.
Can a windows user please confirm?
OS: macOS High Sierra (10.13)
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
Post by chrisb » Sat Sep 19, 2020 9:19 am
This behaviour is known from 0.18 and was fixed in 0.19. You can try to reset the configuration with the button in the preferences, just in case the versions interfere. Another possibility is to delete your config files or to move them in case you want to restore them.
davidosterberg
Post by davidosterberg » Sat Sep 19, 2020 10:20 am
Deleting the config files did not help. Also deleting the whole config directory did not help.
I fired up the good old 0.18 to check the difference.
There everything is working fine
2020-09-19 12_17_38-FreeCAD 0.18.png (1.56 KiB) Viewed 492 times
Note that the pointer and cross-hair is a lot smaller in v0.18.
Post by chrisb » Sat Sep 19, 2020 12:00 pm
Let's see what other Windows users report.
GeneFC
Post by GeneFC » Sat Sep 19, 2020 2:24 pm
I have never seen any problem like that. Selection appears dead on.
I am using the "Gesture" mouse model, and the cursor is an arrow, not crosshairs.
OS: Windows 7 SP 1 (6.1)
Python version: 3.6.8
Qt version: 5.12.1
Also tried the Conda version.
Qt version: 5.12.6
OCC version: 7.4.0
Same result; no problem.
Gene
davidosterberg
Post by davidosterberg » Sat Sep 19, 2020 8:40 pm
Hmm, maybe it is a Windows 10 thing. Perhaps a related issue.
Is it intentional that the font size for some of the text labels are so huge.
E.g., the DOCUMENTS, HELP, ... seem to have much larger font size than the rest of the gui.
2020-09-19 22_34_57-.png (121.33 KiB) Viewed 414 times
GeneFC
Post by GeneFC » Sat Sep 19, 2020 9:30 pm
Still works just fine.
Qt version: 5.12.1
Qt version: 5.12.6
OCC version: 7.4.0
Gene
Locked
Who is online
Users browsing this forum: No registered users and 1 guest
