Regression in git: PartDesign feature Hole UI broken
rynn
Post by rynn » Tue Sep 29, 2020 6:18 pm
In the git version, the UI of PartDesign hole discards the CutType.
Setting the type in the property-list works.
Take the attached example and try to set the hole cut type to “Countersink” oder “Counterbore” in the UI. It get’s displayed correctly while the dialog is open, but the moment you click O.K. the setting is lost.
test.FCStd
(14.13 KiB) Downloaded 26 times
rynn
Re: Regression in git: PartDesign feature Hole UI broken
Post by rynn » Tue Sep 29, 2020 6:47 pm
Prolem seems to be commit fe3f1b51b7be58367d08c5bb0f9f9d292671bb39
vocx
Post by vocx » Sun Oct 11, 2020 5:16 pm
Direct link, git commit fe3f1b51b7.
Post by Kunda1 » Sun Oct 18, 2020 1:19 pm
wmayer wrote: pinged by pinger macro
Site Admin
Post by wmayer » Sun Oct 18, 2020 3:15 pm
I have reverted this commit again. The problem is that the feature overrides the enumerations with the exact same values when clicking OK.
To fix the actual issue #0004371 it's better to handle this in the PropertyEnumeration. The current implementation is:
void PropertyEnumeration::setEnums(const char **plEnums)
    // Setting the enum is done only once inside the constructor
    // but before the current index is already set. So, this needs
    // to be preserved.
    int index = _enum._index;
    _enum.setEnums(plEnums);
    _enum._index = index;
but this doesn't make much sense as it's not checked that the new enumeration has at least as many items as the old one.
See also:
https://forum.freecadweb.org/viewtopic.php?f=13&t=47584
https://forum.freecadweb.org/viewtopic.php?f=3&t=50611
msundman
Post by msundman » Wed Oct 28, 2020 7:26 pm
OK, but now selecting a Hole Cut Type won't enable the Diameter field:
When trying to OK the task it shows an error message and enables the field (and then you can set the diameter properly):
Site Admin
Post by wmayer » Thu Oct 29, 2020 3:37 pm
With my version I cannot confirm this behaviour. When changing the type to Countersink or Counterbore the Diameter filed becomes active.
OS: Ubuntu 18.04.5 LTS (XFCE/xubuntu)
Version: 0.19.22865 (Git)
Build type: Debug
Hash: 3c307b7a3c222d66cb70695cdcf79606553fcb91
Python version: 3.6.9
Qt version: 5.9.5
mendy
Post by mendy » Tue Nov 03, 2020 7:36 pm
I too see this behavior in appimage
OS: Ubuntu 20.04.1 LTS (MATE/mate)
Version: 0.19.22894 (Git) AppImage
Hash: 9eb080488d970d313c538473e7272117ea0a7cd1
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
also in daily
Version: 0.19.
Branch: unknown
Python version: 3.8.5
Qt version: 5.12.8
rynn
Post by rynn » Tue Nov 03, 2020 9:30 pm
Yes.
As far as I can see, the read-only flags are set correct, but are not propagated to the UI.
I can fix it with this:
+        ProfileBased::onChanged(&HoleCutDiameter);^M
+        ProfileBased::onChanged(&HoleCutDepth);^M
+        ProfileBased::onChanged(&HoleCutCountersinkAngle);^M
but I’m not sure if this is the correct way to do.
wmayer wrote: pinged by rynn
Site Admin
Post by wmayer » Wed Nov 04, 2020 9:17 am
This should be OK. The dialog has the method TaskHoleParameters::changedObject and can directly react on changes of the hole feature.
Feel free to create a PR.
Who is online
Users browsing this forum: No registered users and 2 guests
