Arc is missing a constraint
peetervois
Post by peetervois » Sun Oct 18, 2020 9:55 am
Hello, I am pretty new here with FreeCAD but I found that (my version 0.18) is probably missing a arc constraint. The FreeCAD tells me that the sketch is fully constrainted but the Arc in matter of fact has unsolved freedom. By changing the angle in Constraint.a from 30 to 60 makes the arc length to be different. You will see the outcome from attached pictures. It may be possible that I am doing something wrong. I also found that that there is a discussion of sidedness or something going on which may be very similar matter. I was trying to make a construction line to define the centre of arc sidedness with an angle but that fails because the sketch is fully constrained.
proovtiib.FCStd
(6.36 KiB) Downloaded 8 times
peetervois
Re: Arc is missing a constraint
Post by peetervois » Sun Oct 18, 2020 12:15 pm
The reason may be that I have used 2 tangent constraints. I shall use only one, then I can make constraint for the center location. Although I was using tangent constraint, the freedom for the center location was left more than one position, and I think one more freedom must be left to solve.
Post by Kunda1 » Sun Oct 18, 2020 12:32 pm
Please update to 0.19 and retest
(most of us on the forum use 0.19 now as it is far more advanced and stable than 0.18, due to some technical and time constraints 0.19 release has been delayed.)
Also please always past your full About info
Post by chrisb » Sun Oct 18, 2020 1:16 pm
I can indeed not reproduce in 0.19, but I see that your sketch is poorly constrained: You must not use tangency and coincidence on the same points. And you should not use 90° angles, use orthogonal instead. As it is advised to minimize the number of dimensional constraints I would recommend to use symmetry instead of the 0.5mm expression.
For further explanations see https://owncloud.gwdg.de/index.php/s/eZ ... 9/download.
Who is online
Users browsing this forum: No registered users and 2 guests
