Extruded cut by selected lines
mikecarlos
Post by mikecarlos »
After spending hours of time searching in forums and videos. I decided to post it here.
I am designing a closure for electronics. I need to make openeings on the backpanle for connectors. I have imported the STEP of my connector. I selected the perimeter lines of the connector as in the image below. I want to cut my panel (grey) with this shape. How is this possible? Can you help?
Thanks
https://pasteboard.co/JDlLKuU.jpg
Re: Extruded cut by selected lines
Hi and welcome to the forum!
You have to select your enclosure, then the imported Step and make in Part workbench a boolean cut.
mikecarlos
Thanks for the reply.
What if I wanted to transfer the selected edges (the green line in the image) to a sketch? Is this possible.
mikecarlos wrote: Sat Dec 05, 2020 10:53 am What if I wanted to transfer the selected edges (the green line in the image) to a sketch?
You can downgrade the object in Draft workbench and convert wires to a sketch.
mikecarlos
That works! Thx.
