Assembly Challenge: hypnotic geometric thing
Post by Kunda1 » Thu Feb 28, 2019 4:46 pm
phpBB [video]
Anyone interested in testing the different assembly workbenches to model this hypnotic thing?
DeepSOIC
Re: Assembly Challenge: hypnotic geometric thing
Post by DeepSOIC » Thu Feb 28, 2019 5:05 pm
Sketcher counts?
kunda1-thingy-sketcher.FCStd
(4.6 KiB) Downloaded 50 times
Post by chrisb » Thu Feb 28, 2019 5:40 pm
I would have bet that it works only of the diameters of both circles have a certain ratio, my guess was 1:2. Your sketch proves that it is arbitrary within certain limits.
cox
Post by cox » Thu Feb 28, 2019 6:43 pm
I wonder if it is possible to drive more than one small wheels without them crashing in center?
kunda1-thingy-sketcher2.FCStd
(5.16 KiB) Downloaded 30 times
Post by chrisb » Thu Feb 28, 2019 8:19 pm
Open Sketcher and run the code in python console. Outside sketcher additional recompute is needed.
import time
from PySide import QtCore
# call from console: execfile('/Users/cb/panhard/coupe/sanssoupapes/hypno.py')
step = 1.0
timeout = 0.001
angle = 720
def update():
  global angle
  angle -= step
  App.ActiveDocument.Sketch.setDatum(37,App.Units.Quantity(str(angle)+' deg'))
while angle > 0:
  update()
  time.sleep(timeout)
hypno_cb.FCStd
(4.22 KiB) Downloaded 33 times
kbwbe
Post by kbwbe » Thu Feb 28, 2019 10:38 pm
Hi Guy's,
and now without sketcher but with A2plus...
Here is a video:
https://youtu.be/nUQezfutJYs
A2plus has to be installed
1) Copy the attached script to your macro folder
2) Open the attached fcstd file
3) Start the macro
To speed it up i used modified solver accuracy...
With standard options the simulation will be slower.
SOLVER_CONTROLDATA = {
    #Index:(posAccuracy,spinAccuracy,completeSolvingRequired)
    1:(0.1,0.1,True)
Edit:
There was an error in the attached simulation script. It was only able to run on my local installation, but not on a standard installation. I replaced the attached script by a correct one. Sorry ! :oops:
Also i simplified the script.
simulation.py
(800 Bytes) Downloaded 46 times
hypnotic-asm.FCStd
(18.23 KiB) Downloaded 40 times
KBWBE
latest release: v0.4.42b, installable via FreeCAD's addon manager
roerich_64
Post by roerich_64 » Thu Feb 28, 2019 10:54 pm
@ Klaus: 1+ :)
kbwbe
Post by kbwbe » Fri Mar 01, 2019 11:46 pm
The simulation script of my previous post needed to be fixed.
Please find attached the correct files.
simulation.py
(800 Bytes) Downloaded 47 times
hypnotic-asm.FCStd
(18.23 KiB) Downloaded 33 times
KBWBE
Post by Kunda1 » Sat Mar 02, 2019 12:32 am
Wow, what a great response + learning more about FreeCAD in the process!
Thanks to all that participated.
Zolko
Post by Zolko » Mon Mar 04, 2019 1:50 pm
Sketcher counts?
And here is the assembly using your sketch as base (with Asm4):
Who is online
Users browsing this forum: No registered users and 2 guests
