Page 62 of 135
Re: Assembly 4 workbench
Posted: Thu Jun 18, 2020 3:09 pm
by Zolko
WayofWood wrote: ↑Mon Jun 15, 2020 6:53 pm
I extended the code a little bit:
that's cool. Could you explain a little how we could include this into the existing code ? I'm in no way a specialist of BoM and cut-list, so I don't really know the desired workflow.
Posted: Fri Jun 19, 2020 4:42 pm
by WayofWood
Zolko wrote: ↑Thu Jun 18, 2020 3:09 pm
I would have integrated it into the existing code - it's just that I honestly don't understand the entire Python Gui and OO stuff well enough to change the existing BOM file. Let me try to explain how I would envision the workflow:
I would add the code from the A2+ workbench to add a Partinfo table. This code (
https://www.google.com/search?client=ub ... 8&oe=utf-8) could be copied 1:1 with the slight modification that the partinfo object would need to be created within the Assebmly4 model -- not within the toplevel of the document. I find the tables quite convenient to copy the ebay URL, the price, etc. and I would assume that there has been quite a bit of user feedback been collected in A2+.
The generation of the actual BOM is the quite easy: One hits a button, a file save as dialogue requests the filename and the csv file would be written to a file:
a = Partlist(FreeCAD.ActiveDocument.getObject("Model"), 0)
t = dictoarr(a)
fileName = whateverfunctionisusedtogetafilename() # :-)
if fileName:
with open(fileName, 'w') as csvfile:
writer = csv.writer(csvfile, delimiter="\t")
writer.writerows(t)
It would write a lot of information from the partlist table as well as the variables so that everybody should find the data they need.
Would that make sense?
Posted: Fri Jun 19, 2020 11:39 pm
by Zolko
Hello,
I'm pleased to announce that a new version of Assembly 4 has been released, v0.9.5, with a new measurement tool, completely rewritten from the Caliper of the Manipulator WB. This tool can now measure almost everything that you throw at it. I'd be happy if you could test it and report all problems.
There is also some preliminary functionality for BoM and Part Info:
WayofWood wrote: ↑Fri Jun 19, 2020 4:42 pm
Instead of a spreadsheet, I added the info directly as property to the Part (works also for Bodies). This is still very early work in progress. I'm really not used to cut-lists and part-lists and BoM-s, so all help and suggestions would be welcome.
Posted: Sat Jun 20, 2020 9:07 am
by fc_tofu
Hello, @zolko,
As my final step in usual Assembly4 workflow, to hide LCS one by one is a little tedious.
So, would you add a new command for future release, "Show/hide All LCS" ?
I know in assembly project there are also LCS made not by Assembly4, ie, default LCS of a PartDesign body.
I have not thought very clear how could the suggested "Show/hide All LCS" neglect non-Asm4 LCS.
Hope other people here also give advices.
Posted: Sat Jun 20, 2020 5:51 pm
by drmacro
Some experiences with the latest A4 release and the daily build.
Not really sure if what I saw were interrelated...or not.
I put the development zip from the other day in to test. Did some quick tests and made the report the other day. Promptly forgot I had replaced the /.FreeCAD/Mod/Assembly4/ folder. Since have done daily build updates.
Today I loaded up an assembly I'd done over this period. Even though it loaded the assembly and did the usual partial load of the part files (or even if I had the part files loaded) it did not show any of the LCS's from the part files. (So, any attempt to move a part offered no part LCS's to choose, or anything other than the Parent Assembly & it's LCS.) It also did not show any of the parts, or newly loaded additional parts when attempting to link a part.
I then used the Addon manager to install the latest A4 (measure tool, BOM...) and things are back to normal.
On a side note: I have a TechDraw page in the assembly file. And when I do a section view I get this warning:
DVP::extractFaces - SectionView -Can't make faces from projected edges
I mention it because I'm not sure what this means and it only happens in the section view in the assembly. (and it happens on every recompute.) I did note the section origin was shifted off the y axis by -.603mm, don't know where that came from either... The warning happens even after the origin is set to 0.00.
Posted: Sat Jun 20, 2020 8:42 pm
by WayofWood
Zolko wrote: ↑Fri Jun 19, 2020 11:39 pm
I am clearly not expert when it comes to BOMs. At the end I think it's mainly personal taste if it is a spreadsheet or a property. I think in any case it would be beneficial if a couple of configurable field names (like supplier, product name, price, etc.) would be given as a template. Otherwise there is a risk that "suplier" is not correctly matched and it's just more typing.
The number of clicks would also be the one objective measure for a spreadsheet. When I fill out the part info I usually have the supplier website in a browser and the spreadsheet in the other window. I then copy name, URL, price, etc. one by one. With the spreadsheet I can copy the value directly - with a variable or property I would have one more mouse click to do ...
Posted: Sat Jun 20, 2020 10:53 pm
by OficineRobotica
Zolko wrote: ↑Tue Jun 16, 2020 3:21 pm
-this is more of a trunk version small usability issue. The Icons for create LCS, datum plane, datum axis etc in part should be more "colorful" when active. There is little to no contrast between states especially when using a dark style sheet.
If you can propose something I'd be glad to include it
The difference is subtle on the small scale of the icons in the toolbar but significant , at least for me, for giving the hint of a active or inactive icon during editing.I'm still not 100% happy with how they look but it seems to work for me for now. I'vd done nothing special, just aded some stroke of color to the icons.
- example.png (794.14 KiB) Viewed 3358 times
Posted: Sun Jun 21, 2020 8:59 pm
by DDM
For my job (strcutural steel elements for buildings) I create BOM like in the example attached.
Steel manufacturing companies generally ask this:
1) BOM for single parts (for cutting list and material order)
2) BOM for assembly (for workshop operations and transportation/erection operations)
3) BOM for bolts (for material orders)
I am trying to use Assembly 4 workbench for steel building parts. This workbench seems promising...
Thanks for your job,
Cheers,
Marco
Posted: Sun Jun 21, 2020 10:50 pm
by Nash Rambler
Hello Zelko! Is your "Lego_House+Garden" assembly available as a downloadable FreeCAD file? I would like to learn from it. Thx!
Posted: Mon Jun 22, 2020 3:35 pm
by Zolko
OficineRobotica wrote: ↑Sat Jun 20, 2020 10:53 pm
thank-you, yes that's better. I've updated the workbench with these icons. Also improved the measure tool
