FreeCAD for Woodworking
webmanoffesto
Post by webmanoffesto » Wed Oct 30, 2019 6:08 pm
Can you recommend tutorials on FreeCAD for woodworking.
At this point I'd be happy if I could design a bookshelf.
That means vertical pieces, horizontal pieces.
Front or back not very significant yet, maybe just a 1/8" piece of wood for the back.
Dimensions set in a spreadsheet, so I can change them.
Each board is a separate file, and they are assembled (Assembly4?).
I'll need a cut list.
I worked through Woodworking with FreeCAD, by WayofWood
Parametric Japanese Box, using A2Plus assembly
https://www.youtube.com/watch?time_cont ... fNBfdIpzDQ
but that leaves out a lot of the process.
I like that it uses
Alias Manager Macro
Creating a Cutlist, that's essential
Rendering in 3D image, that's a nice plus
I understand that Assembly with the Assembly 2+ is no longer maintained. I think I should be using Assemblty 4.
More Detailed Project Description https://wayofwood.com/woodworking-designs-with-freecad/
I'm starting on
Designing with spreadsheets in FreeCAD
https://www.youtube.com/watch?v=_pITOzeqJ0Y&t=234s
vocx
Re: FreeCAD for Woodworking
Post by vocx » Wed Oct 30, 2019 7:35 pm
Assembly2 is obsolete.
Assembly2+ doesn't exist.
A2plus is the successor of Assebmly2, and it is very much alive and maintained. But it is not compatible with the original Assembly2.
Assembly3 and Assembly4 are workbenches that use the new "App::Link" element, introduced in 0.19. They are still experimental, but they may be good enough for your usecase.
Assembly3 cannot be installed from the Addon Manager yet; Assembly4 can be installed from the Addon Manager.
Zolko
Post by Zolko » Thu Oct 31, 2019 12:39 pm
what's a "cutlist" ? Is it like BOM (Bill Of Materials) ?
Jee-Bee
Post by Jee-Bee » Thu Oct 31, 2019 1:51 pm
i think it is same as what in dutch called a 'zaaglijst' most used for stock products like beams that is bought on default lengths and are just cut off from this lengths.
most of the time there are no drawings from it just a list, a (raw )material, length and amount of every peace...
Post by Kunda1 » Thu Oct 31, 2019 2:07 pm
ov10fac
Post by ov10fac » Sun Dec 01, 2019 1:30 am
Similar as you say. But many woodworkers in the USA now use plywood and the cut list helps to optimize the use of a sheet of plywood. At $50-$80 a sheet, we woodworkers like to get the most parts possible from a sheet, hence we spend a lot of time developing a cut list.
Who is online
Users browsing this forum: Baidu [Spider] and 1 guest
