Reimplementing constraint solver
DeepSOIC
Re: Reimplementing constraint solver
Post by DeepSOIC » Tue Dec 17, 2019 3:11 pm
A small update. The development slowed to a crawl. The main reason is I had trouble with establishing structures for placed geometry support.
I think I've come up with a reasonable solution, it's 2D version is being finished now.
I've opened issue tracker on the repo, to gather some things I postpone.
New year holidays are coming. I plan traveling. There will be little to no development in the coming three weeks.
Post by Kunda1 » Tue Dec 17, 2019 6:56 pm
Thanks for the update and heads-up. !
triplus
Re: Call for team! Reimplementing constraint solver
Post by triplus » Wed Jan 15, 2020 5:40 pm
Trying to compile the branch i get the following error:
src/Mod/ConstraintSolver/App/SubSystem.cpp:221:58: error: no matching function for call to ‘FCS::Subconstraint::Subconstraint(<brace-enclosed initializer list>)’
             _subconstraints.push_back(Subconstraint{c, ie});
In addition would it be possible to provide an example code snippet to test:
DeepSOIC wrote:
Mon Nov 25, 2019 12:51 pm
Base classes for geometry and constraints are up, with just one concrete geometric thing and one constraint implemented (point and distance). This should be enough for initial experiments on solver.
Thanks.
Site Admin
Post by wmayer » Wed Jan 15, 2020 6:40 pm
Looks like you need to use C++14
Example 1:
#include <vector>
struct test {
  int a;
  int b;
int main()
  std::vector<test> vec;
  vec.push_back(test{1,2});
gcc init.cpp -std=c++11 -lstdc++ => works
Example 2:
#include <vector>
struct test {
  int a;
  int b = -1; // a member is already initialized in the class declaration
int main()
init.cpp: In function ‘int main()’:
init.cpp:11:25: error: no matching function for call to ‘test::test(<brace-enclosed initializer list>)’
init.cpp:3:8: note: candidate: test::test()
struct test {
init.cpp:3:8: note: candidate expects 0 arguments, 2 provided
init.cpp:3:8: note: candidate: constexpr test::test(const test&)
init.cpp:3:8: note: candidate expects 1 argument, 2 provided
init.cpp:3:8: note: candidate: constexpr test::test(test&&)
gcc init.cpp -std=c++14 -lstdc++ => works
triplus
Post by triplus » Wed Jan 15, 2020 9:04 pm
Thanks for the info.
P.S. Will wait a bit to see if @DeepSOIC will still be prepared to support C++11 (Ubuntu 16.04). For me personally this is not a huge problem, could update the toolchain or migrate to Ubuntu 20.04. But generally speaking maybe supporting C++11 still makes some sense? That is talking from the next FreeCAD version (that will come after the FreeCAD 0.19 release) point of view.
DeepSOIC
Post by DeepSOIC » Thu Jan 16, 2020 10:06 am
see src/Mod/ConstraintSolver/examples for a starting point. Though they might not work right now...
DeepSOIC
Post by DeepSOIC » Thu Jan 16, 2020 10:09 am
... But generally speaking maybe supporting C++11 still makes some sense?
I didn't know I am using c++14 features. I aimed for c++11. I guess my toolchain supports c++14, which made me use some c++14 features by accident.
Site Admin
Post by wmayer » Thu Jan 16, 2020 1:07 pm
git commit 0b2b1e3a536 now prints which C++ standard is being used. When configuring with CMake you should see it in the output window.
With the CMake macro https://github.com/FreeCAD/FreeCAD/blob ... tups.cmake we can choose the C++ standard from a combo box but obviously the value is only set for the clang or gcc compiler and is ignored for MSVC.
But am not sure if by forcing it to C++11 the compiler will abort for C++14 (or later) code because often compiler extensions are used automatically.
triplus
Post by triplus » Thu Jan 16, 2020 6:17 pm
Good to see all the progress and to hear supporting C++11 is still on the plan. No hurry, but will wait for the C++11 fix to land. After i will try to compile again and test the examples.
DeepSOIC
Post by DeepSOIC » Wed Jan 22, 2020 11:30 pm
I am now seriously considering shifting the focus to 3d sketching.
Who is online
Users browsing this forum: No registered users and 2 guests
